Home > Technical (L322) > iid tool info
Gollycrush
England 2006 Range Rover Vogue 4.4 V8 Cairns Blue
iid tool info
Is there a function with the iid tool to turn off the cold monitoring function of the rear lights? i suffer with the flickering lights at start up ( recently had a 2012 conversion to my 2006MY vogue ) is the tool easy to work with or do you need a degree in electronics? advice would be very much appreciated.
Post #140199 8th Sep 2012 6:40pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
IID does have the option to turn off cold monitoring per light. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #140202 8th Sep 2012 7:17pm
hot and cold on each light neil... ... - .- -.
Post #140207 8th Sep 2012 8:05pm
DMRR
Indeed, but he only asked about cold Wink Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #140208 8th Sep 2012 8:06pm
his next question might be about the hot monitoring.. Wink ... - .- -.
Post #140209 8th Sep 2012 8:07pm
DMRR
It could be, or it could be about fitting black badges lol Wink Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #140210 8th Sep 2012 8:09pm
Laughing
btw goolycrush, the IIDTool is very easy to use and does a lot more ...there is a q&a thread in technical that is worth reading... ... - .- -.
Post #140211 8th Sep 2012 8:12pm
mpirie
Wow, you mean the iiD tool monitors that as well?
Man it just gets better and better ! Whistle
Post #140221 9th Sep 2012 6:02am
The most impressive thing my IIDTool does is change punctures whilst traversing along the dual carriageway at 55mph...What a clever bit of kit it really is Thumbs Up
Post #140223 9th Sep 2012 7:32am
verydisco
Hi DM, could you be more specific as how to turn it on and off please? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #140225 9th Sep 2012 7:58am
DMRR
Hi,
Make sure you have the latest version of 2.17 firmware, and the options for each light are in the LCM settings. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #140232 9th Sep 2012 8:42am
verydisco
DMRR wrote:
Hi,
Hi, I am quite sure I have the latest version, the device was delivered 2 weeks ago straight from Canada.
Under what name/denomination should I find this in the LCM settings please?
On a side note, this tool is magic, I did play with it a bit (unfortunately not much to go in depth yet) but I already turned on some nice options such as the Follow Me Home with all lights on, the DRL at 40% and so on.
Cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #140236 9th Sep 2012 8:58am
V.D. have a look at the first post here http://www.fullfatrr.com/forum/topic12418.html it has a brake down of the functions.. ... - .- -.
Post #140250 9th Sep 2012 11:42am
verydisco
Cheers Stan.
That will do perfectly thank you. Thumbs Up
Let me try it and see if this sorts the fog light issue too... l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #140252 9th Sep 2012 11:52am
Thumbs Up ... - .- -.
Post #140254 9th Sep 2012 11:55am
