![]() | Home > Wheels & Tyres > Wheel nuts for different alloys Guide |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
anyone? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I can't see why the taper is present on the chrome one or the purpose of it (unless the 7 spoke alloys are thicker). Doesn't the nut pull tight against the washer? If so, they look like they are both the same depth to the washer. The tapered section effectively passes right through the wheel holes. From the pic, it looks like the chrome one is slightly longer due to the taper, so wouldn't the tapered section come into contact with the hubs first, which would then tighten before the washer has started to seat, making the rim loose? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 ![]() ![]() ![]() |
Its not the length that matters it's the girth...sorry just being smutty. The silver ones are about 3mm wider to fit all post2006 wheels. Expect Ken will be along soon to put you all right but this topic has been covered before.
So, if I want set of locking wheel nuts, I just ask for post 06 ones then? I have the wheel nuts with the 7 spokes, but 2 lockers are missing. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
yes.
Not sure what nuts I have here, but they won't touch my studs. Smaller internal diameter on the chrome ones 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35609 ![]() ![]() |
no , they wont fit..
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
Ok I'll have a look thanks |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
LR part RRD000011 for up to 2005 wheels |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 ![]() ![]() ![]() |
I have a 2005 l322, going to be putting these wheels on
Yes they will fit but so will these. I have them fitted on mine.
thanks a lot, got them done today, the old wheels had spacers and allsorts. thanks vmuch |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Hi, just to doubly double check before spending a lot of money tomorrow.
