Home > In Car Electronics (L322) > Engine Code on Nav screen |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
hi there and welcome to the forum..
5th Sep 2012 7:45am |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I think if you put the key in the ignition and turn to the first stop the CODE will be highlighted in white.
5th Sep 2012 7:48am |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 |
Yes, that's what happens on mine. When the engine is running its greyed out. As the ignition key is turned to position 1, it lights up, and I can enter a code, it then says something like "remove key to activate" |
5th Sep 2012 8:30am |
alahmed Member Since: 03 Jun 2012 Location: Jeddah Posts: 62 |
Thank you so much Stan , Budgie and Tsadpt. after reading your replies i was able to activate the code and registered a new code but there something strange happened !! i was able too to start the engine without entering the code !!! please see the picture and the video clip i have taken http://www.flickr.com/photos/78049469@N06/.../lightbox/ Thank you Ahmed |
6th Sep 2012 8:33pm |
possibly you didnt save the new code? [if there is a 'save' that is] ... - .- -.
6th Sep 2012 8:36pm |
6th Sep 2012 9:14pm |
i'm not familiar with that setup as i have a touch screen on mine, but you could try a battery dis-connection..this 'might' reboot the ecu's and set them to default....if you do remember to turn the steering wheel fully let then fully right after you have re-connected the battery [with engine running] ...procedure is on the wiki.. ... - .- -.
7th Sep 2012 7:16am |
Thank you Stan
7th Sep 2012 12:27pm |
cant see that affecting the firmware as normally a newer sat nav disc just updates the nav firmware.. ... - .- -.
7th Sep 2012 12:34pm |
Thank you stan anyway |
13th Sep 2012 9:21am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7834 |
Where is the firmware for the computer screen actually stored ?
13th Sep 2012 9:55am |
