Home > Maintenance & Mods (L322) > Bluefin not resetting to original.
ahebron
New Zealand
2003 TD6 HSE
Went to reset Bluefin back to original setting today. Did as instructed and device said all done but the car would not start and dash kept reading everything as a fault. Revert back to Bluefin setting and I have no OBC display below instruments. I plug in the factory stereo unit to try to reset but nothing. The Display still works as I can use IID Gap tool on it. The push button on the indicator stalk does nothing but the display remains lit.
So I have 2 issues
1) Bluefin will not reset to original
2) OBC is not working after attempted reset
Are the 2 linked, seems like it to me as no problems before attempted reset. But maybe just bad timing.
Has anyone else had any of these problems?
I have sent Bluefin an email regarding the first matter and am awaiting a reply.
Maybe if I use the TestNr function I can sort my display?
I will try battery disconnect for 30 minutes for now
Adrian VW Amarok 2014 Highline auto
Post #139489 5th Sep 2012 12:16am
ahebron
New Zealand
Well battery disconnect did not work!
And I could find nothing in the Test NR settings.
Post #139499 5th Sep 2012 7:09am
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
A few weeks ago I investigated Bluefin for my TD6. I rang up and asked one of the technical people if my existing modifications (K&N, EGR removed and de-cat) would be a problem. He told me that Bluefin would not be appropriate for such a vehicle, as the system was designed for the car in it's standard form. No further discussion was forthcoming, so I left it at that.
I notice that you have similar mods, so I hope your problem isn't linked with this. There's probably no connection, but I thought I'd mention it.
Post #139508 5th Sep 2012 8:19am
ahebron
New Zealand
Thanks for the reply Sea Aitch.
I can't see how those should make a difference as all they will do is bring up a soft fault code if any. A KN should not make any difference. The Cat has no circuitry to it and the EGR only has a vacuum feed. I assume the computer reads the amount of vacuum to sense whats going on.
I have just been and checked all the fuses and they as expected are all good. There is power to the old radio feed as I plug it in and use that to reset the clock or other settings.
And to top it all off I am now getting trans fail safe messages but I suspect that to be the transfer box motor resistor thingy. I will whip that off and give it a clean and good look at. I love looking at ridiculously expensive machinery that doesnt work. Crying or Very sad
Post #139511 5th Sep 2012 8:34am
It might be worth a call to Superchips, as the first thing the unit usually does is back up the original map, so it should be in there somewhere.
IIRC, the s/w package that comes with the unit should allow you to offload it onto a PC via USB. Got - 2017 SDV8 Autobiography in Loire Blue
Post #139518 5th Sep 2012 8:57am
ahebron
New Zealand
That is the first thing I did sfter it happened.
Well not quite, as I am in New Zealand and it was about 10pm UK time I sent an email. Wink
Post #139520 5th Sep 2012 9:00am
Might be best to wait for them to reply, just in case you end up losing the original map, which could leave you right at the start of a very bumpy and long Censored creak with no paddle to be found! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #139523 5th Sep 2012 9:03am
ahebron
New Zealand
Good old Bluefin came back with an original setting which I have just successfully fitted.
But no OBC, hmmm. Confused
Post #139709 5th Sep 2012 9:46pm
At least you've got the original map back Thumbs Up
Small steps and all that! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #139759 6th Sep 2012 11:17am
ahebron
New Zealand
Anyone got any ideas?
Does anyone know where the OBC resides on a 2003 TD6 HSE?
Is it a seperate box or part of another component?
Thanks
Post #143429 28th Sep 2012 5:30am
ahebron
New Zealand
This is the latest reply from Superchips
The older dashboards were notorious apparently but we haven’t heard anything for a long time, certainly about this exact problem. Whilst it is fairly obvious that the diagnostics process we go through has highlighted the problem, it is unlikely that it is the root cause. It would be certainly be a worthwhile exercise plugging in with a diagnostic tool to see what fault codes are stored and whether they can be erased, or it used directly to restore all dashboard displays
So has anyone had experience of this with their old dashes?
I have the IID Gaptool so will this pull the necessary codes but if it does where do I find what they mean.?
Thanks
Post #143863 1st Oct 2012 7:28am
