Odd one....
When braking and the box is downshifting from 2nd to 1st as you come to a halt it is as if the Gearbox isn't 'letting go' similar to if you are coming to a halt in a manual and forgot to press the clutch until the last minute and then the engine revs drop then stutter back to idle again....
It doesn't do it all the time, only occasionally, as I say it is as if the clutch isn't slipping until the engine revs drop then they stutter and pick up and back to idle....
Also when braking and you have the windows open you can hear a click from under the car fairly central....not a menacing click, just a mechanical click....doesn't make this click when crawling, only above 10mph or so....
Any clues as I'm stumped.
4.4 2003 Vogue on Gas....
