Home > Wheels & Tyres > Will RRS alloys work with TPMS
Nick66
2007 Range Rover Vogue SE TDV8 Java Black
Hi
This may be a daft question but I have seen a set of 20" RRS alloys that I would like to fit to my 07 RR Vogue Se, will this affect the TPMS or can the valves be swapped from my standard wheels onto the RRS wheels?
Thanks in advance for any advice.
Nick
Post #138895 1st Sep 2012 11:23am
Nick66
I think I've worked it out, the monitor and valve are all one part and fit inside the rim so you just remove and re use on new wheels?
Please correct me if I'm wrong.
Thanks
Post #138925 1st Sep 2012 4:00pm
nbunney
If you just fit the RRS wheels Whistle then you will get errors messages, as the TPMS valves are missing.
You could try and change the TPMS valves, but they do tend to break.
Post #138961 1st Sep 2012 7:15pm
Nick66
Thanks for the reply.
So tyre fitter could try and take TPMS valves out and fit them to new wheels but they may break? And this will be the same not matter what wheels I fit, unless they already have TPMS valves fitted?
Post #138966 1st Sep 2012 7:31pm
Yes, the TPMS valves will almost certainly break when being removed...
Secondly, the Sport wheels will be the wrong offset for your 07 so will stick out much further... Also the tyre sizes will be wrong for yours leading to amongst others the wrong speedo reading...
Craig Thumbs Up
Post #138995 2nd Sep 2012 7:22am
Nick66
Cheers Craig, you have saved me from making a costly mistake there Bow down
Post #139033 2nd Sep 2012 11:25am
Thumbs Up Whistle Thumbs Up
Craig Thumbs Up
Post #139036 2nd Sep 2012 11:41am
