Home > Wheels & Tyres > 22 inch supersport help needed. Can anyone identify the fake
Britishlion
Hi All
So just posted the car the My Range Rover section as a newbie. Need some urgent help please !
When i bought the car last week one of the alloys and two of the tyres had been kerbed badly. The alloy in question had such a ding that the garage has said needs changing.
So on to eBay i went and won a set of 3 alloys and tyres for a nominal amount ! very very happy, until i went back to the garage and he said they are different alloys ! I never even noticed but such a small difference. Here are the new alloys
Alloy 1 is off eBay with brand new tyres
Alloy 2 is on the car and needs changing
So, my question is, which alloy type is genuine/copy and what is the best way to go now ? try to hunt out a fourth alloy and tyre or sell them back on eBay as the 3 and start again ???
Thanks in advance everyone
A very confused BL Yawn
Post #138904 1st Sep 2012 12:46pm
Assuming they are genuine Overfinch , do any of them have the word Overfinch stamped on the inside or a number ….
Or did the ebay advert say "style" which would mean copies … Thumbs Up
Post #138905 1st Sep 2012 12:58pm
SteveF
I have genuine Overfinch on mine as far as i am concerned that look exactly like the one you have damaged.....check out the slight recess in the cut out and take a look at mine in gallery.
Hope this helps Thumbs Up
Post #138906 1st Sep 2012 1:06pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I have a set of these on my car (genunines).
The one on YOUR car looks genuine.
The set of 3 your purchased on eBay are replicas.
Post #138909 1st Sep 2012 1:31pm
Allan
As above;
Alloy 2 looks more genuine but should be stamped with Overfinch somewhere.
Alloy 1 look like copies and I would be a bit wary of fitting them. You need to check that the load ratings for the tyre and the alloy are correct for your vehicle before you do. Otherwise you risk a wheel failure. Just because they have been advertised as 'will fit' doesn't mean they are suitable. Sorry.
My advice would be play safe and buy a set of genuine LR alloys and tyres off eBay.
Post #138932 1st Sep 2012 4:37pm
Britishlion
Thanks everyone
I will get the suspension up tomorrow and have a look under the car at those on it
The alloys from eBay say apple on them and a few other bits will post later
I thought the ones on it looked more genuine and the guy who did the facelift has used all genuine parts so would have been surprised if they were fake. Just gutted I didn't notice the difference of the disgn on the eBay ones, but at least I got three good tyres out of it !
Will post when I find out , thanks again for all your help
Post #138941 1st Sep 2012 5:06pm
LostInSpace
New Zealand 2006 Range Rover Vogue SE Supercharged Java Black
Alloy 1 is fake
Alloy 2 should be genuine
The holes at the end of the spokes are a sign - on the fake there's one smooth radiused edge, on the genuine ones theres a step. If the are genuine, they will have Overfinch cast into the back of one spoke, you'll need to remove the wheel to see.
The early Supersports didn't have Overfinch on the front face of the spoke.
I'd advise you check the inside rim of all the alloys (fake or not) for cracks - these are prone to cracking, but can be repaired. 2006 Supercharged
1990 Porsche 928 GT
Post #138955 1st Sep 2012 6:29pm
LostInSpace
Alloy 1 is fake
1990 Porsche 928 GT
Post #138956 1st Sep 2012 6:30pm
They are both fakes IMHO, Yes number 2 is a better quality fake, probably a european one and number 1 is probably from china... Genuine Overfinch alloys dont take Land Rover centre caps...
Craig Thumbs Up
Post #138959 1st Sep 2012 7:06pm
LostInSpace
^^^^^ that's very true Craig Bow down 2006 Supercharged
1990 Porsche 928 GT
Post #138964 1st Sep 2012 7:29pm
Turbo Tony
Agreed, the ones on the car seem to be the genuine ones. Look at the difference on the edge of the spoke, where it meets the rim.
The ones on your car have the same ridge, as shown in this picture:
http://www.overfinch.nl/range_rover_sport/...rsport_22/
...Although I gotta say, the lip on yours seems more pronounced than in the genuine pic. Researching my first Range Rover purchase
Post #139030 2nd Sep 2012 10:33am
SteveF
Cam-Tech-Craig wrote:
They are both fakes IMHO, Yes number 2 is a better quality fake, probably a european one and number 1 is probably from china... Genuine Overfinch alloys dont take Land Rover centre caps..:
Mmmm....slightly worrying Shocked
Will have to check mine when back in the UK!
Post #139034 2nd Sep 2012 11:29am
Check out the size of the centre caps in these originals...
Also, the way to tell if you have a good strong wheel, weather its a copy or OE is to look inside the wheel and see if its a cheap flat wheel in its construction or if it has big strengthening ridges designed into the construction... Makes the wheel much much stronger with the ridges... Look inside a standard FFRR wheel for the ridges...
Craig Thumbs Up
Post #139037 2nd Sep 2012 11:49am
Britishlion
Thanks Craig
Very useful info that, I believe all mine are replicas then ! I am away with work so unable to check till the weekend as to wether they are or not, to be hoest just need to find an alloy like them to replace the damaged one. Been looking on eBay but not spotted anything yet
Will keep searching
Thanks for all the help everyone
Post #139122 2nd Sep 2012 9:25pm
Your welcome sir... Thumbs Up
Craig Thumbs Up
Post #139124 2nd Sep 2012 9:43pm
