Home > Maintenance & Mods (L322) > 6 pot brembo
Bigkev
England 2010 Range Rover Vogue SE TDV8 Santorini Black
6 pot brembo
Can anyone tell me if these will fit my tdv8 MY10?
Part numbers are LRO 16659 &  LRO 16661.
I don't know why they dropped the brembos from the 2010 but they obviously realised the mistake as they where re-introduced in 2011 I believe.
Thanks
Kev
Post #138383 29th Aug 2012 5:19pm
i believe mick [joker] has the same thoughts re this mistake..... ... - .- -.
Post #138401 29th Aug 2012 7:43pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
+1 for "this mistake" mine are far worse than my old 2003 FFRR and way behind the wife's D3 Big Cry
I thought about this upgrade but not sure how effective the retro upgrade would be and is it just a case of calipers, pads and discs?
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #138403 29th Aug 2012 7:59pm
Bigkev
If these will fit, then I think it is a case of the calipers, disc, pads and possibly the flexi hoses but possibly the hoses are a standard thread, although braided hoses may be a worth while upgrade.
I just don't know if the mounting holes on these match those on my car?
Kev
Post #138406 29th Aug 2012 8:09pm
What you need to check is weather the holes in the casting (hub carrier) are big enough for the calliper mounting bolts to mount the Brembo callipers...
Found this out this week trying to fit a set to an 06MY V8 for a customer! They would fit apart from the holes being bigger on a 10MY calliper carrier/casting...
Craig Thumbs Up
Post #138407 29th Aug 2012 8:13pm
Bigkev
Craig,
So what you are saying is the bolts for the larger calipers are fatter than the holes in the hub carrier?
If this is the case, how much larger and would it be possible to enlarge the holes in the hub carrier via drilling them out?
Thanks
Kev
Post #138413 29th Aug 2012 8:20pm
You can change the hub carrier for the 10MY onwards and then they will bolt straight on... £265ish per side... I priced them as an option...
To drill out the casting would not IMHO be an acceptable practice...
Craig Thumbs Up
Post #138414 29th Aug 2012 8:27pm
Bigkev
So as mine is a MY10 they should bolt straight on?
Also Craig, was going to pm you regards my rear lights, I have seen the rear lights that you opened up, removed the red rings, smoked the clear lens, and painted the surrounding plastic black.
Do you offer this as a service or were they just a one off for your demo car?
Thanks
Kev
Post #138416 29th Aug 2012 8:40pm
You may be able to get away with carriers made up to fit them but they may not sit right.. As above, or maybe find a slightly older smashed up one and get the hubs and setup off that Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #138422 29th Aug 2012 9:01pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
I'd want to be sure that nothing else was different (master cylinder, ABS set-up, bias etc.) before bolting completely different brakes on. Balance could be totally changed.
Post #138426 29th Aug 2012 9:36pm
Thanks
Kev
Kev, yes i can make you a set sir... But they are very time consuming and therefore expensive... You need two rear lights as you have to smash the clear cover off one and then cut the plastic away from the rear of the other...
Price of 4 rear lights...
Labour of about 20ish hours...
That said, weve made three more sets for customers since...
Craig Thumbs Up
Post #138428 29th Aug 2012 9:56pm
You also have the issue of ABS sensors being seized, wheel bearings as you normally have to press out the drive shaft therefore having to split ball joints etc etc... Could easily turn into the expensive job from hell!
Craig Shocked
Post #138658 30th Aug 2012 9:56pm
Other than the lines i dont think the other parts are different TBH but worth comparing VINS and microcat Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #138716 31st Aug 2012 9:12am
Its not a case of the other parts being different, its the other parts are not made to be removed and refitted... IE the ABS sensors can not be removed as they are plastic and either seize in or are glued from factory (like a Discovery 2) so when changing the carrier, the ABS sensor would most likely have to be replaced! And the wheel bearings would and maybe other componants like ball joints (have to remove when taking off the hub to press out the drive shaft) that have a habit of rubbers splitting when you try to remove them... That's before tackling the drive shafts! Could get very very expensive is all im saying... Thumbs Up
Fine if the customer is happy to pay, parts labour etc etc but as an unknown quantity, it's very hard to quote a job like that...
Craig Whistle
Post #138731 31st Aug 2012 10:04am
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Also if you are running with MY10 19" wheels then they too won't fit over the larger Brembos meaning that you will have to source MY11 onward 19"wheels Sad
Post #138735 31st Aug 2012 10:09am
