Home > Maintenance & Mods (L322) > leaking FF!
allycraven
leaking FF!
Gents, the FF has suddenly lost its water integrity somewhere along the front driver side and am at a loss what it could be.
When parked sideways on a hill nose and right side lowest (in the rain) I'm getting a fairly substantial leak into the cabin that appears to be coming from the side of the dash and bonnet release lever recess and running into the door sill and speaker etc.
When I open the door I'm greeted by a big splash of water that has pooled inside the weather seal and there is obvious water trails on the speaker vent in the door and the bonnet release recess and the side of the dash is 'moist'.
Weather seals all seem to be OK round the door, so am thinking windscreen- any thoughts?
Post #137955 27th Aug 2012 2:22pm
Sunroof drain blocked in the A pillar?
Pour a small amount of water in the corner of the sunroof tray with the sunroof open and see if it runs out the bottom or not!
Craig Thumbs Up
Post #137958 27th Aug 2012 2:28pm
mjdronfield
Sunroof drains...........? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #137960 27th Aug 2012 2:29pm
mjdronfield
Ah, Craig must have beat me by a few seconds...........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #137961 27th Aug 2012 2:30pm
Ner Ner Banging Head Ner Ner
Craig Rolling with laughter
Post #137962 27th Aug 2012 2:32pm
allycraven
Thanks guys, its still raining so won't need to add any water,..
If it is that, what's the procedure for unblocking....
Post #137964 27th Aug 2012 2:33pm
mjdronfield
The school of thought if you look on the net, appears to be to use compressed air up the tube in reverse.
I have read issues where this has blown the other end of the drain off the sunroof, causing even more issues.
When I had an issue on the Range Rover Classic, I used a line from a Strimmer, as it's fairly strong and blunt at the end.
I fed it down down the drains from the corners of the sunroof..........
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #137969 27th Aug 2012 3:04pm
allycraven
spot on, thanks guys! Definitely the s/r drain on the driver side.
Have tried a long wire, 2ft was longest I could get hold of. also a compressed air keyboard cleaner but to no avail.
Have resorted to parking with the nose uphill for now to try and minimise the volume of water getting into the sunroof and booked into the dealer Wednesday if I can't get it cleared at home tonight.
Where do the drain hoses come out so I can take a look underneath later on?
Post #137972 27th Aug 2012 3:31pm
mjdronfield
Not sure on the L322, but I'd imagine you'd have to take the inner wheel arch liner out....
...just had look on the net.......
This may help, but its for a P38 Range Rover.
http://www.rangerovers.net/repairdetails/sunroof/drains.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #137974 27th Aug 2012 3:42pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Bicycle brake cables are usually good for this. You can often get a 5m piece from your local bike shop for around �1. If the end frays a little they are even more effective, but get harder to work with.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #137976 27th Aug 2012 3:51pm
Ah, the pleasures and smugness of owning an HSE..... Thumbs Up .
Post #137981 27th Aug 2012 4:24pm
mjdronfield
Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #137983 27th Aug 2012 4:30pm
