Home > Maintenance & Mods (L322) > how does this come off
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
any ideas how this comes off is it just stuck on
http://www.ebay.co.uk/itm/Black-Rear-TAILG...58880ca8a3
Post #137620 24th Aug 2012 4:03pm
Slides downwards
Post #137629 24th Aug 2012 4:33pm
SteveMFr
Site Sponsor
47p2 wrote:
Slides downwards
Huh? Generally just stuck on (at least the ones I've seen).
Removing can require judicious heat gun usage.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #137631 24th Aug 2012 4:37pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Recently did this on mine, just pull it off, stuck on with double sided foam tape. I did the lettering at the same time , some powerful kits come with a rubber drill attachment to take the residue off, just don't press too hard .then use some cutting compound to finish it off. Make sure you get the new strip lined up properly when sticking on.
Post #137636 24th Aug 2012 4:47pm
