Home > Technical (L322) > Front Suspension Depressurising |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
Before I get on to my question a BIG THANKS to Joe90 for the how to on changing the front air springs
24th Aug 2012 1:38pm |
I thought there was only one block and both sides connected into it |
24th Aug 2012 2:38pm |
Thats what I thought but I dont have the block.
24th Aug 2012 2:48pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
WTF !
24th Aug 2012 2:49pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
24th Aug 2012 3:30pm |
But the question is can I still deflate the air spring without it and WITHOUT stabbing it with a knife? |
24th Aug 2012 4:09pm |
Yes, as Meerbusch says, if you can get a 12mm spanner on the nut at the top of the airspring and turn it enough to allow a trickle of air out, then wait a good while for all air to leave the spring. Battery disconnected (best) or minimum air compressor fuse removed, of course!
24th Aug 2012 5:00pm |
24th Aug 2012 5:02pm |
Looks like your car has been...Tangoed
24th Aug 2012 5:07pm |
What's a t-w-a-t-o? .
24th Aug 2012 5:54pm |
The car has been Tangoed and is 'd |
24th Aug 2012 10:54pm |
Cheers for all the replies |
25th Aug 2012 5:19am |
Bob, can you not trace the pipes and see if the valve block has been relocated (which I doubt).
25th Aug 2012 7:04am |
