Home > General > Water drain?
boffhead
Water drain?
Hi,
I've got water dripping from a drain on the underside of the car....... It's just on the near side of the centre diff. Is this just an air con condensate drain or something more sinister?
Thanks in advance. Chris
Post #137386 23rd Aug 2012 11:44am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sounds like Air-Con drain....
As long as the water is clear and not coloured, it's not from the engine! (Assuming you have coolant rather than just tap water in the rad!)....
Post #137391 23rd Aug 2012 11:57am
if you've had your air con on then its what simon says...if you havnt had it on ,then good luck.. ... - .- -.
Post #137419 23rd Aug 2012 3:04pm
