Home > Technical (L322) > 06 Touch Screen Brightness adjustment
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I've searched and failed to find an answer ...
In daylight the touch screen on my 06 FFRR is fine - but it doesn't appear to dim at all when the headlights are turned on.
If I turn down the instrument lighting to minimum, I can't read the rev counter - but the screen is still too bright - is this something that a dealer can adjust (I know abou the option to turn the screen off, but the sat nav is useful ...) ?
Post #13699 23rd Feb 2010 1:26pm
in the menu there is a bightness settings you can adjust manually , that long since i used it i would have to go back out to the car to tell you the exact way of doing it ====================================
Post #13701 23rd Feb 2010 1:28pm
VaguelyVogue
Thanks - I hunted around, but couldn't see anything obvious (and nothing was mentioned in the manual) - so back to the car later to check ...
Post #13709 23rd Feb 2010 2:19pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
If you are using auto headlights, for some reason the screen is very bright, and slowly dims over a few minutes. You have proved this by using the rheostat to dim the instrument panel.
Don't ask me why, but this is a quirk on quite a few cars.
Post #13724 23rd Feb 2010 5:23pm
Top left hard button, into screen settings I think from memory Discovery 4 HSE
Post #13732 23rd Feb 2010 7:18pm
VaguelyVogue
Found it thanks - just surprised that it's a manual adjustment rather than dimming automatically when the lights come on !
However - I can certainly live with it !
Post #13866 25th Feb 2010 2:10pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Mine automatically dims when I turn the lights on. The manual brightness is just to tailor it to your personal preference as to how bright you want it. So basically, if you wait until dark, turn your lights on, then manually adjust the brightness to the level you want at night, you shouldn't need to adjust it again. If there is indeed an issue with the auto-lights option not triggering the dimmer properly (I don't use them so never notice) then obviously what I've said will make no difference in those circumstances. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #14113 1st Mar 2010 3:31pm
