![]() | Home > Maintenance & Mods (L322) > Steering Wheel Upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Having seen Joshdee's upgraded steering wheel yesterday, I'm thinking this would be a nice upgrade to my 2003 car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
havnt done this myself but there are these threads that might give you some help,
Thanks Stan. Normally a massive advocate of the search, thought I'd quickly post up my query before dashing out the door......
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
I upgraded mine to the nappa leather chrome heated wheel. Genuine. I then sold my old one on and got a few bob, so
With you now Craig. My wheel isn't that bad, had I not seen the upgraded one, it'd not have entered my head to change it.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
The nappa one also has a thicker rim and is much nicer to hold.
Thanks all.
Just ordered a soft nappa leather genuine new one from DCC 4x4.
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
I'm still trying to get my feckin air bag off |
Yep it can be tricky if the wire is not aligned correctly.ur basically pushing a tab inwards, if u have a led torch u can look in and see the tab ur supposed to be pushing. Keep at it u will get it eventually. |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Fancy one of these myself but I have read conflicting reports about it being plug and play on the heated version - what's the verdict ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
When I upgraded the steering wheel on my old car I was sent a "tool" to remove the airbag. Basically it's a small screw driver with the head cut off |
Mine was heated, 06my. 'twas plug and play BUT one connection was v slightly different but sorted it by cutting off a bit of the plastic . Now the wheel heats up lovely and evenly. |
