Home > Maintenance & Mods (L322) > Squeaky belt on start up.
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
When I start my car from cold I get a slight belt squeak. (Car is a 2007 S/C). Once the car has been running for a few minutes it goes away.
I'm a bit sh*t when it comes to mechanics, but it sounds like it's the lower of the two belts as I look under the bonnet. I did put a little squirt of WD40 down there a week or so ago, and the squeak went immediately, but it came back very quickly. Confused
Is this something I can adjust myself? (Given that I'm about one grade above a monkey with a spanner). Rolling Eyes Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #136474 17th Aug 2012 11:09am
You should NEVER spray WD40 on rubber belts as it deteriorates them, spray a little water on them to identify if that is the source of the squeak
Post #136475 17th Aug 2012 11:12am
http://www.fullfatrr.com/forum/topic11354.html?highlight=squeaky
http://www.fullfatrr.com/forum/topic7763.html?highlight=squeaky ... - .- -.
Post #136476 17th Aug 2012 11:13am
jfb1977
D'oh!! Embarassed
And thanks Stan.... Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #136478 17th Aug 2012 11:16am
Gollycrush
England 2006 Range Rover Vogue 4.4 V8 Cairns Blue
Squeaky Start up
i suffered this problem back in oct 2010 of the squeaky belt noise on start up. "Stratstone" changed Fead Belt PQR500320, idler Pulley PQR500350 and a modification to the mounting bracket, Bottom front crank seals, The pulley, shim and nut. The Bill �720 but Cured the problem.
Post #136532 17th Aug 2012 3:52pm
jfb1977
Shocked For �720 I can live with a few moments of squeak on start up! Wink Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #136539 17th Aug 2012 4:15pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I changed both belts (alternator and AC) and it went away Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #136554 17th Aug 2012 5:49pm
