![]() | Home > Maintenance & Mods (L322) > Does anyone know how the Autobioraphy side skirts fit? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
There are about 10/12 push in clips under your original black sill, remove all of them... One smaller clip each end into the wheelarch liner... Open all the doors and gently work from the rear to the front easing it off, the top is held on by push clips (the same as a door card)
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Thanks for that, sounds relatively simple. |
It is easy as Craig says even I could do it! Check my gallery file 24 and you will see them fitted. They look much bigger off the car rather than on |
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 ![]() ![]() |
Thanks for posting the pic - I didn't even realise the Autobiography came with special skirts. Researching my first Range Rover purchase |
Well its part of the exterior design pack
