Home > General > Replacing Side vents
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi There,
Does anyone know how easy/difficult it is to replace the grey double side vents. And how to do it ?
Cheers
Jonny
Post #1331 20th Nov 2008 4:34pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Very easy
remove the plastic lower part of the wing
Unbolt the vent (bolts top of vent and bottom of vent)
remove vent & rev process to fit
Post #1332 20th Nov 2008 4:53pm
How to Install Range Rover Side Vents
Tools Needed: 10mm Socket or wrench
Time Required : 30~45 min. for pair
Step 1
Open the hood and locate the screw on the top of the vent.
Step 2
Reach the bottom of the lower panel (the panel underneath of the vent) and pull hard towards you. The panel (made of plastic) is flexible and fastened by clips.
Step 3
Do not take off completely. It will make you difficult to put it back.
Step 4
Remove the top screws using 10mm socket or wrench.
Step 5 & 6
Locate the bottom screw and remove it using 10mm socket or wrench.
Step 7
Remove the vent.
Step 8
Removed.
Step 9
Compare the new Supercharged (A) and original (B) vent.
Step 10
Remove the back panel from the Supercharged vents. They would not fit without removal.
Step 11
Back panel is removed.
Step 12
Install the new Supercharged vent (Installation is a reversal of removal).
Step 13
Push back the lower panel securely.
As Gordon Ramsay would say DONE !!!!!!!!!!!!!!
Post #1334 20th Nov 2008 5:34pm
ken
Mick Question Step 10 didn't do that on mine wonder if its a MY change
Same as my process but guess you had more time to expand Thumbs Up
Post #1339 21st Nov 2008 7:58am
Only reason i expanded on your thread Ken , was because the neighbour pulled the bottom plastic cover fully off as in stage 3 and had one hell of a time trying to get it back on, so it was mostly to advise any other member in case the same happened to them.
Sorry if it sounded as if i was using the Lawnmower.................... Thumbs Up
Post #1340 21st Nov 2008 8:27am
ken
Must have changed the design then caus no issues at all with the side vents and later fitted the mud Flaps
Post #1361 22nd Nov 2008 2:59pm
