Home > Technical (L322) > Passenger door lock broken?
ikilla2
2003 Range Rover HSE Td6 Stornoway Grey
Fellas, a little heads up required; pulled the passenger door handle to open the door yesterday and felt a small pop/ snappy feeling..needless to say the door didn't open! Now I have a passenger door that dosent open from the outside. My guess is a small but significant plastic clip has snapped? It may be a shot in the dark but does anyone know the part number of this part before I strip the door down to assess the situation? Assuming this is a common problem.
2003 L322.
Thanks in advance.
Post #135953 15th Aug 2012 7:58am
done a search and found this , hope it helps,
http://www.fullfatrr.com/forum/topic11580....=door+lock ... - .- -.
Post #135956 15th Aug 2012 8:13am
ikilla2
Tried searching but on my phone and proved fruitless!
Even though I can open from the inside it may be the cable?
Post #135979 15th Aug 2012 10:00am
2 cables in the door, one from outside and one from the inside, sounds like the outside one is broken...there are microcat links in the wiki for you to find out the part number or you can ask dan @ duckworths.. ... - .- -.
Post #135982 15th Aug 2012 10:05am
ikilla2
That for swift reply.
Where is the wiki?
Post #135986 15th Aug 2012 10:12am
under the big fullfat banner up top.. ... - .- -.
Post #135988 15th Aug 2012 10:13am
http://lrparts.ru/engl/
http://lrcat.com/ ... - .- -.
Post #135990 15th Aug 2012 10:15am
ikilla2
Topman.
Post #136013 15th Aug 2012 12:08pm
i think this is what you want,
http://www.ebay.co.uk/itm/Land-Rover-New-R...415bf6a56c
or,
http://www.ebay.co.uk/itm/Range-Rover-L322...35b82ec377
or,
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...56466014b1
check with sellers though.. ... - .- -.
Post #136014 15th Aug 2012 12:13pm
ikilla2
Already ordered, thanks for the replies.
Post #136102 15th Aug 2012 7:58pm
