Home > General > Windscreen Manufacturing Defect? |
Windscreen Dave Member Since: 28 Jun 2012 Location: Lincoln Posts: 29 |
If the stone had sufficient force to crack outer glass and then push onto the laminate interlayer it is possible that it could crack inner layer of glass and then for small shards to come off. It is highly unusual but can happen. Is it original glass or has it been changed? |
14th Aug 2012 5:22pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 |
14th Aug 2012 5:27pm |
All front windscreens are now laminated. Unfortunately I don't think that you'll be able to push it through as a defective screen as these sort of things can happen I have seen swans penetrate the whole screen ending up on passengers lap, not a pretty site. The job of the windscreen when debris is flung up at it is to deflect or if sufficient force absorb the impact. It is not bullet proof (although you can get this option for an extortionate price). Therefore there is a chance that you wil get a small amount of debris in the car. It is far better than the old screens that used to be toughend like your door glass or back screen that would just shatter. |
14th Aug 2012 5:40pm |
Forgot to say if your insurance is fully comp you should have windscreen cover on it so will only have to pay xs. |
14th Aug 2012 5:45pm |
Ok thanks very much Dave.
14th Aug 2012 5:52pm |
