Home > General > How does your heated windscreen perform?
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Don't get me wrong I love the fact I've a heated windscreen but it kinda annoys me that it doesn't defrost the whole screen.
Does 6-8" in from the passenger side and 3" or so in from drivers!
Is this normal? TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #13570 22nd Feb 2010 10:25am
Same as mine ......... 6" from the passenger side thought it was just mine that was gubbed ........ Thumbs Up ====================================
Post #13572 22nd Feb 2010 10:40am
SteveMFr
Site Sponsor
My pass side is your drivers - and I've got about 3" on both sides. Look closely at the windshield during daytime. You can see the very fine wires embedded in the glass. If there are wires where there is no defrost, you have a prob.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #13576 22nd Feb 2010 11:16am
dan_uk_1984
No, this is not normal, you need a new screen. Ring your ins co and say there is a chip and you DONT want a repair.
Mine was dirty on the inside and no amount of cleaning would get rid of the smear so I got a new one, just had to pay a £75 excess.
Post #13578 22nd Feb 2010 11:21am
Macdaddy
Thanks,
thought I'd post here and check what's normal before I put in a claim for a new windscreen.
I get wind noise from the windscreen seal anyway so could cure two jobs! TDV8 HST Sport **Current**
Post #13581 22nd Feb 2010 11:33am
Macdaddy
How does the new one perform Dan? 3" from each side? TDV8 HST Sport **Current**
Post #13582 22nd Feb 2010 11:34am
Thought about doing that myself but may end up with the odd leak somewhere after being fitted anyhow i don't need to see out the passenger side .......... Rolling with laughter ====================================
Post #13584 22nd Feb 2010 11:37am
dan_uk_1984
Autoglass did mine, but I have noticed they've introduced a wind noise that wasn't there before. Upon further investigation the side trims aren't stuck down properly because they re-used them. I'll order some more and then it should be 100%.
The thing to do is to go over it after they've done it to make sure it's ok. I'd definitely get it done again without a worry.
Dan
Post #13586 22nd Feb 2010 11:47am
And make sure they are careful around the wiring from the rear view mirror! Autoglass cut through eight wires when changing my screen on a previous FFRR.....
Post #13612 22nd Feb 2010 2:50pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
had mine done and it works a treat 3 inch from each side love it autoglass did it and it went well apart from they droped the first one and had to re order and rebook Censored 02 Range Rover HSE Zambezie silver 4.4
Post #13626 22nd Feb 2010 8:07pm
If you can avoid a new screen I would, it can only add to your problems. Discovery 4 HSE
Post #13636 22nd Feb 2010 9:32pm
Macdaddy
How come? TDV8 HST Sport **Current**
Post #13637 22nd Feb 2010 9:35pm
Andy
you can't repair heated screens anyway. We had a Fiesta XR2i once and that was heated. There was a couple of stone chips and we looked into repairing them. We found a company who came out and ended up splitting the screen. Ended up going to Autoglass who said no repair should have taken place. Any reputable company won't repair as it damages the heating elements (which in our case were already damaged due to the chips). 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #13638 22nd Feb 2010 10:14pm
dan_uk_1984
That was my argument with my ins co, that the chips had already damaged the heating elements. My screen was really pitted and one of the chips had started to spider, in fact I have a whole thread about Autoglasss Windscreen replacement: http://www.fullfatrr.com/forum/topic919.html
& RRUK: Why would it add to his problems? His heated screen doesn't currently work, a new one really is the only way to go. Plus there is no way to tell if this is already a replacement screen. A surprising amount get broken whilst shipping from factory to the dealer and they end up calling autoglass out themselves.
Post #13649 23rd Feb 2010 8:40am
inkiboo
Switzerland 2007 Range Rover Vogue SE TDV8 Java Black
If they call out Autoglass and have the screen replaced then it will not have the LR logo on the glass. It's exactly the same screen (made by Pilkington) but any replacement will not have a LR logo.
Post #13651 23rd Feb 2010 8:45am
