Home > Maintenance & Mods (L322) > oil leak v8
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
oil leak v8
My car leaks oil which seems to come from the top of the engine. What could be the cause of this oil leak as initially the Indie told me its coming from the sump gasket but now tells me that its the cylinder (top) head gasket.
Your advice is appreciated
Post #135551 12th Aug 2012 6:25am
fisha
There is a rubber seal that runs seals the magnesium head covers ... Trouble is that the wrinkle finish that develops on the magnesium also occurs in the grooves where the rubber seal sits and then pushes the rubber away and allows oil to seep through.
There are quite a lot of reports of it on the BMW forums and it's a relatively straight forward part to replace. V8 or else ...
Post #135570 12th Aug 2012 9:34am
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Hi there,
Check the breather pipes at the back if they are perished they may be leaking and tracing down the head. Ideally I would take the pollen filter housing out and get in there yourself and see if you can see anything.
Thanks
Brian
Post #135665 12th Aug 2012 10:22pm
vnitos
guys thanks for the replies
where can one buy the parts other than at dealers - ive tried duckworths and famousfour but they did not respond to my request for quotations. im looking for:
- PCV
- PCV hoses
- rocker cover gaskets
- cam cover gaskets
Post #137205 22nd Aug 2012 2:59pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
I am in the middle of replacing the pcv hoses-got them from BritCar.
Fraser
Post #137216 22nd Aug 2012 4:36pm
