Home > Technical (L322) > Instrument Cluster failure |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
It doesn't sound like you need a new instrument cluster to me. Sounds like your mechanic didn't change the brake pad sensors, or else you need the fault code resetting which he perhaps didn't do. |
10th Aug 2012 9:31am |
ramclaren Member Since: 09 Aug 2012 Location: London Posts: 9 |
I've just posted this in the "in car electronics" forum which is maybe more suitable. |
Hi Simes,
10th Aug 2012 9:33am |
Always expect the simple solution to be the correct one matey... |
10th Aug 2012 9:37am |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
Welcome!
10th Aug 2012 9:48am |
To be fair to them, they spent a whole day checking everything they could think it could possibly be and deduced that its the cluster. I have to say though, one cluster specialist said that he fixes 60-70 a week and has never heard of one doing this. |
10th Aug 2012 9:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 |
first thing to do ram is to dis-connect the battery, the procedure is in the wiki, and then re-connect ...
10th Aug 2012 10:11am |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 |
I changed my pads and sensor a few weeks back, and it took a couple of days for the system to acknowledge that I had infact changed them and to stop b!tching about it...
10th Aug 2012 1:47pm |
Sorry for the delayed responce, I was knocked off my bike on friday cycling home from work. A few broken bones and some nice cuts and grazes have laid me up for a few days.
14th Aug 2012 12:09pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Can they change clusters ? I was under the impression it puts a small pixel up in the mileage box to indicate that the mileage has been tampered with ! ? |
14th Aug 2012 12:48pm |
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 |
I had the pad warning for several days after sorting the sensor, turn on ignition without starting then wait for warning to clear. |
14th Aug 2012 8:24pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
As long as all the various modules that store the mileage read the same, then the tamper pixel wont show. Likewise, if the replacement speedo is adjusted with the correct software to read the current mileage, the tamper pixel wont show, as all the modules match the same. Just realised, Cartronix are just up the road from me, may have a nosey at them Reformed |
14th Aug 2012 10:39pm |
Hi guys,
18th Aug 2012 1:12pm |
Just thinking; the fact that it cleared the "low key battery" message but not the "check brake pads" one makes me think the problem is not the cluster, it's something else.
18th Aug 2012 1:27pm |
