![]() | Home > Technical (L322) > Creaking when turn steering wheel right 360 degrees at acces |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Worn or Creaking Bushes maybe....when in Access Height the geometry is different and emphasises the problem |
Check the bottom balljoints |
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 ![]() ![]() ![]() |
Interesting, I renewed my LR warranty just the other week and as part of it a full inspection is done, surely something like ball joints would have been picked up?
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I had something similar, turned out to be the top mount on the LHS - I removed the top cap and sprayed some WD40 around the top bearing and it went away instantly.
Sounds promising!! I'll give it a go when I'm back home on Thursday.
