Home > Technical (L322) > Special Programs Off ? |
I suggest to check for all the fuses to be "tight", wiggle/push them into the sockets. Check earth/ground connections and spray with electrical contact cleaner. Clean if necessary (corrosion reduce voltage a lot by creating resistance and 12 V does not need a lot of resistance to go down a few volts), take connection off, sand/brush to bright metal and apply light coat of vaseline or contact cleaner. Same for the battery clamps, take them off, clean them with sandpaper as well as the battery poles themselves, light vaseline and back on again. MY 2010 5.0 SC Galway green and sand interior!!
4th Aug 2012 8:22am |
SteveB Member Since: 12 Jan 2012 Location: Kent Posts: 56 |
I fitted a new battery only six months ago. I will double check all the connection again as I did suspect a bad connection somewhere. Like all RR problems, there is not always a pattern to them reoccurring. This fault reoccurred seven times in 10 miles then seemed to clear and I had trouble free driving for another 10 miles. I will check all again this morning Steve B
4th Aug 2012 8:28am |
Yes the old Vaseline trick... |
4th Aug 2012 8:29am |
Checked fuses all ok, no corrosion, all fitted securely. Battery has no corrosion and all connections clean and tight. Went for a drive and about two miles out I got up to 70mph and ding ding same again. Engine fault but no warning lights and special program's off flashes up on the centre screen and into get home mode, crawling along. Off and on and all clears.
4th Aug 2012 10:55am |
Checked all one more time and still no different. All ok until I boot it up to 70+ then fault comes on. I have read it could be the turbo or EGR valves....any ideas? Steve B
4th Aug 2012 12:25pm |
EGR fault is common on the TDV8 and a pig of a job to do |
4th Aug 2012 12:50pm |
I have been getting a good puff of black smoke when I kick down or accelerate hard, is this a sign of blocked or faulty EGR valves? I had one replaced only 10 months ago.
4th Aug 2012 5:02pm |
It has turned out to be a split turbo hose only £20.00 Steve B
6th Aug 2012 2:21pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
Mines just done exactly the same thing.
10th Feb 2013 5:19pm |
Mine was the left side main turbo hose on top of the engine. Very easy to replace. Mine was split about 2" long on its underside, hence i didn't see it until I really started pulling and pushing the hoses around. It only happened at speed when the turbo pressure went up and opened the split creating an un-balanced air flow and then the double ding. Lift bonnet, take off engine cover and really give the two turbo hoses a good check over including the hose clamps. Hose was about £25.00 and 15 minutes fitting. mind you it took two days of trial and error to find the split in the first place.
10th Feb 2013 5:54pm |
Thanks - I will have a look - I got the error message twice on the motorway from Lyon - loss of power, over to the hard shoulder, off and on again and it seemed fine. After the second time, I dropped the speed, we were nearly there anyway.
10th Feb 2013 6:13pm |
I can't figure out which hoses I need to check. It's -12 at the moment so none of them are particularly flexible either
14th Feb 2013 5:13pm |
