Home > Technical (L322) > Air Suspension Inactive
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had a quick jaunt to the shops this morning and got the 'air suspension fault' come up.
At home had a look under the car and found the front passenger side suspension height linkage sheared off where it connects to the strut. Jacked the vehicle up and the ball joint linkage had corroded right through - so drilled out and using a 20mm long M6 Stainless nut and bolt with washers , effected a temporary working repair. However the suspension still comes up as faulted and I was wondering is it a trip to the dealers or is there something I can do myself - disconnect battery etc ? My dealer is a round trip of 40 miles ! Sad
Post #133427 29th Jul 2012 11:27am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Dear mercs600, only with clearing..., for example RSW all comms or GAP, or you can try to go to a BMW dealer, he has the same software.
Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #133447 29th Jul 2012 4:14pm
Have you tried lock to lock on the steering wheel? There is nothing that can't be fixed with a hammer😜😜
Post #133449 29th Jul 2012 4:18pm
mercs600
Thannks for the advice - also yes I did the lock to lock but it still shows the fault Sad Looks like the stealers it is then Sad
Post #133484 29th Jul 2012 9:02pm
