Home > Technical (L322) > Violent wheel wobble - anyone cured this? |
highfellzippy Member Since: 20 Aug 2011 Location: Yorkshire Posts: 153 |
swap the wheels with someone
27th Jul 2012 7:19pm |
can't see it being the diff........... i got more vibration stationary in D after the recall swap was done......
27th Jul 2012 7:41pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
I had a similar wobble between 75 and 85, it turned out one of the REAR tyres was / not circular any more.
28th Jul 2012 4:37am |
I was going to ask why the mechanic went to Halfords to balance them..... .....I would'n trust them to open a can of pop properly.
28th Jul 2012 7:59am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I don't like the sound of a LOT of balance weights added to wheels.
28th Jul 2012 9:21am |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
Thanks for the replies so far chaps - the new wheels are genuine LR, with logo and serial numbers cast into the metal. Probably the next thing would be to get new tyres instead of the Continentals, and get all the bushes replaced after that, since my mechanic was happy that there was no significant wear.
28th Jul 2012 9:32am |
Just one further thought, all your wheels nuts are tight I assume. |
28th Jul 2012 10:55am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I had the same symptoms. Driving at about 50+ if I changed direction I got bad wheel/steering shake. The worst was long sweeping corners on motorways.. In the end it was the ball joint on a lower control arm. I replaced both myself, there are photo guides on this site.. Total cost about £50, and no more wobble. Previously..
28th Jul 2012 12:02pm |
I'm liking the sound of that - my wobble only happens with just a little left turn of the wheel, and disappears on straightening up and is exactly the same - on long sweeping motorway curves..
28th Jul 2012 3:12pm |
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 |
Had exactly your symptoms for a while now. Checked wheel balancing three times and used spare on OSF ( where I thought prob was). Always the same slight left turn at 65+ and big wheel wobble just like a faulty shopping trolley!
29th Jul 2012 7:26pm |
Thanks for that Stocky - I was driving today and the logic of it being worn bushes makes sense - the wobble is only with small steering deflections, whereas bigger inputs cancel the wobble - I guess small steering changes allows the worn bush/link/ball joint to be under less tension and so move about more. I've got some parts on the way tomorrow, but I now want to replace all the ball joints and the upper control arm bush as well, just to make sure. |
30th Jul 2012 6:56pm |
Yes it was just slight turns left, go tighter and it disappeared. |
30th Jul 2012 7:16pm |
30th Jul 2012 8:42pm |
Right - had the drop links and front control arms replaced today, and I've just come back from a test drive down the motorway, and.....IT'S GONE!!!!!!
2nd Aug 2012 6:36pm |
