![]() | Home > Technical (L322) > s/c Gear Box |
I'd suggest to quickly do a megaflush or filter/fluid change, hopefully it is just the oil getting dirty.
npikey Member Since: 14 Nov 2011 Location: Lincolnshire Posts: 59 ![]() ![]() ![]() |
Right I've spoken a man that can, and the first step is to check the levels as he thinks the judder is low oil then have it in for valve body stripdown, rework and oil/filter change, £650+ the dreaded and all should be sorted, any view's or comments ??
Have a look at electrical connectors as well. I had similar warnings coming in at random, transmission gear change range limited and transfer box not available. I just checked all the fuses for being tight and haven't seen it since. As the faults were completely random and very shortlived (seconds) I am pretty sure it is connectors (it was during rainy season so going through deep puddles a lot).
Thanks |
