Home > Maintenance & Mods (L322) > IIDTool from Gap Diagnostics
Page 11 of 15 <123 ... 101112 131415>
Just ordered mine so looking foreward to a play.
FWIW I paid £286 which I found from 2 suppliers (LRParts and Norse 4x4) but several more at various prices with £348 plus postage the most I was asked to pay. That's quite a variation so deffo worth a quick search. If there's better bargains that I found out there it would be handy if they could be posted up somewhere for future generations....but pls not before I've gone offline! Wink Mike - MPx
Post #132096 20th Jul 2012 12:12am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Got mine from LRParts fast delivery and best price I could find. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #132111 20th Jul 2012 8:00am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Sorry MPx Mr. Green
Just paid £278 inc. VAT, P+P from here - http://4mostoffroadparts.co.uk/index.php?r...uct_id=554
An impulse purchase but the things IID can do are increasing by the week!
Does the licence code come with the IID?
Post #132123 20th Jul 2012 8:59am
nubbin, you stick the IIDTool into your obd port and it generates a number, you then email this number to GAP and they send you an activation code which you enter into the unit when its plugged in the obd port.. ... - .- -.
Post #132126 20th Jul 2012 9:04am
nubbin
Oh right, thanks for that Stan. I don't know, buy a FFRR at a bargain price, then front end conversion, LPG conversion, new set of wheels, new tyres, and now an electronic spanner - starting to get expensive this!
Mr. Green Mr. Green Mr. Green Mr. Green
Post #132137 20th Jul 2012 9:15am
all the fun in owning a fullfat mate.. Thumbs Up ... - .- -.
Post #132148 20th Jul 2012 9:36am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
C1A20 error code suspension
Hi Steve or whoever can help.
I am getting an error code in RLM suspension:
C1A20 pressure increases too slow when filling reservoir.
I also now and again get the suspension fault, normal height only notice on my dash when driving not all the time. Also hear some hissing when I get out of the car, but again intermittent.
Are these the tell tale signs of a leaking bag? How can I tell which one?
Thanks in advance.
Post #132268 20th Jul 2012 11:19pm
sounds like the compressor is on its way out lolo... Crying or Very sad ... - .- -.
Post #132288 21st Jul 2012 8:53am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi lolo
Normally, when an air bag is leaking, the vehicle will become crooked when left unattended overnight. If it stays straight, your air bags are fine. Also, you may get other fault codes if an air bag was defective.
This fault code can be caused by three things:
1- The compressor is worn out.
2- The compressor is used extensively in a short period of time and heats up (toggling from access to off-road repeatedly for example).
3- The compressor is attempting to fill the reservoir but it is not able due to a leak.
Since you mentioned the possibility of a leak, case 3 would be a more plausible cause. Your leak is probably located between the reservoir and the valve block. This is where you should start investigating.
Cheers!
Post #132678 24th Jul 2012 1:39pm
Ginger
2006 Range Rover Vogue 4.4 V8 Santorini Black
Can anyone tell me how much it is for a second IID tool licence?
I've not bought one yet but just wanted to know the cost if I change my car.
Cheers
Post #132688 24th Jul 2012 2:23pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
Hi
I asked them the same question, here's the reply;
Quote:
Hi Damian
Yes, the unit is transferable to another vehicle if you ever sell it and buy another one. Its free of charge for the original purchaser.
Thank you
Patrick Meilleur, ing jr
GAP Diagnostic
Great eh?
Not sure how much it is to add a second vehicle rather than transfer though...
Post #132731 24th Jul 2012 6:48pm
Flashman
Wow, now that is a great service. Another reason to keep to Range Rovers.... Tom
Current Drive
Previous Drives
Post #132752 24th Jul 2012 8:09pm
that's really good if you do change your range...a pretty much future proof unit.. Thumbs Up ... - .- -.
Post #132753 24th Jul 2012 8:09pm
Ginger
Thanks Aurrian
You can't get fairer than that !!!
Update:-
Order placed!
Post #132815 25th Jul 2012 9:16am
Lolo
PatGAPInnov wrote:
Hi lolo
Cheers!
Ok thanks, its what I thought from all the reading of old threads. I'm hoping it is a pressure sensor, because when I start the engine, and I fiddle with the heights they fill or deflate v quickly without any problems, or It could be the compressor overheating during driving cause of a leak, but the leak is most probably a pin hole cause I have never seen the RR lob sided, only the odd hiss. Hopefully I get a few months out of it either way, I'm v busy doing some bathroom renovations at the mo Thumbs Up
Post #132941 25th Jul 2012 7:07pm
