Home > Maintenance & Mods (L322) > Steering angle sensor initialisation |
Height sensors are about £25-30 per corner and need to be calibrated once fitted.
15th Jul 2012 10:11pm |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
Sorry - was asking about the steering angle sensor. African Bush Junkie ... in London!
15th Jul 2012 11:09pm |
Yes it can be caused by faulty alignment |
16th Jul 2012 12:04am |
Thanks - I'll try that.
16th Jul 2012 11:55am |
If the battery has been disconnected you need to do the steering lock from side to side. Worth a try as the fault could have been caused by a poor battery or connection |
16th Jul 2012 12:26pm |
Update on my HDC Inactive/Suspension Lowered issue.
7th Sep 2012 5:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35126 |
firstly i would consider getting a new battery especially now winter is on its way..it seems that when you re-start the range the ecu's get a burst of power resulting in the ecu working properly until the voltage starts to run down and causing errors...
7th Sep 2012 6:22pm |
