Home > Technical (L322) > Servotronic Valve / Hydraulic Transducer |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 |
Thanks robbo770 !!
11th Jul 2012 7:16pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
Mine is currently getting this done, bottom torx head is sheared off, top one untouched as yet. Garage suggested cutting the mounting lugs off the old part then trying to free off the old screws with molegrips or similar. Only problem is if they can't get them out then the rack will need to be dropped out! Undecided as to what to do next as I need the car for a run down to Donnington at the weekend.Although they may come off when the old unit is slid off, I really don't know what to do! |
12th Jul 2012 7:45pm |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
That's what's happening to mine tomorrow. The bolts are rusted solid so wrecking the old unit is the only answer. About 2-3 hours work. Still the suspension is fine. |
12th Jul 2012 9:57pm |
Tally ho!just away to phone them to proceed with caution, will be smiling or crying shortly ! |
13th Jul 2012 7:07am |
Oh well , garage now too busy today, he is worried that if it all goes wrong his ramp will have a broken ffrr on it until they can drop the rack, so I put up with lumpy low speed steering until either je has time for it or I find someone else in the meantime . Joy !nubbin, can you give me a report on your mechanic's progress for any tips/tricks he uses please? |
13th Jul 2012 7:24am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
the garage will be the best place for your range if that screw is tight in there...i can see that i was very luck mine came off so easily when mine was done.. ... - .- -.
13th Jul 2012 8:26am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
MrT while your waiting why don't you get the servo sprayed with WD40. Can't but help when you do get into he garage. People think because WD40 was sprayed on something 30sec previous it should be free. In reality it can take a while and if you have time might save you lots of ££ in the long run. I'm going to spray mine and I don't even have a problem, but just in case might save me a big ball ache! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
13th Jul 2012 9:13am |
Mix a little diesel and ATF fluid together and use that as a freeing agent
13th Jul 2012 9:16am |
Ball burst for today , garage booked solid ! |
13th Jul 2012 9:32am |
Well I decided that as the FFRR was up on the ramp I would try and remove the bolts for my Servotronic valve. I soaked them in a diesel/ATF mix overnight and today I started the process of loosening them. You need a T20 Torx and using an L shaped Alan-Key type Torx I managed to remove the top one without too much hassle.
13th Jul 2012 4:16pm |
i can confirm that the new servotronic valve does indeed come with 2 brand new screws... ... - .- -.
13th Jul 2012 4:52pm |
So do you have the two new ones kicking around or even the old ones lying abandoned somewhere? |
13th Jul 2012 4:54pm |
valve was done ages ago john so i doubt it.. ... - .- -.
13th Jul 2012 4:58pm |
Well, My trusty mechanic has replaced the valve, and hey presto - it has made no difference at all to the steering shakes at 60-70mph
13th Jul 2012 6:24pm |
