![]() | Home > Technical (L322) > Sitting in D whilst stationary |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Sorry, was rush typing, I meant is N not the same as P..........mechanically, but without the lock parking pawl thing ? 2011 Range Rover Vogue SE 4.4 TDV8
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2604 ![]() ![]() |
I'm all for mechanical sympathy, but I'll wager all that constant loading and unloading of the entire drivetrain by going into and out of gear causes far more wear than just leaving it in drive and gently holding it on the brakes. |
But its the torque converter!!!
Good point........
I suppose you could be doing mechanical damage to properties the transfer fluid if you leave it in D when stationary.
Arrgh!!
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Not sure about the boxes in the L322, but many older ZF boxes are damaged if you leave the engine running for too long in N. This was due to the oil flow round the box not being correct - in fact I think the oil pump only worked in gear. |
My understanding is that certain older boxes don't take the pump drive from the input shaft, directly or indirectly, but that's why you shouldn't tow automatics with the driven wheels on the ground. |
He is stopped to remove a tree, so going to neutral/park is normal. Same arguments as in my first post - you can add trees and LR Experience instructors to the list of begonias, pets, and small children. ![]() And going to N and releasing the brake before going to P ensures that there is no pre-load on the parking pawl.
This is absolutely correct for the ZF 5 HP 22/24 found in the P38. I'm pretty sure this was corrected for the later ZFs found in the L322 (RRPhil would know) and it was never an issue for the GM5L40E in the TD6. And you had to leave the motor running for a long time (and usually at higher RPMs too) such as for AC charge/diagnosis in a garage. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
The impeller of the torque converter is basically an oil pump and therefore requires power to drive it.
Speak of the devil - hi Phil!
Really! But then the MPG difference between manual and auto versions of the same car should be greater, tho, shouldn't it? ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Hi Steve,
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
So, in basic terms, what you're saying is that being in N in traffic when stationary is better and a lot more economical? Si. <This is my name.
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Life is too short to worry about the tiny difference being in D or N or P at the lights will make - my L322 is 10 years old and drives perfectly, messing with the selector at the lights is not going to do anything to it (other than scare the person behind when I select R by mistake). "On first name terms with my local Dealer......now."
