Home > Technical (L322) > Rear Wiper
Rear Wiper
Just recently the water jet from the rear window has stopped, but the rear wiper motor is still working but no water , have tried putting a fine needle into the hole of the jet in case it was bunged up with dirt , on doing this small droplets of water start coming thru , but when i go to use the rear wiper -- Nothing no jet of water ..........
Any ideas Guys Thumbs Up
Post #1307 17th Nov 2008 9:56am
This happened with mine after I bought it, would take ten wipes of the screen before any water came out.
I think they replaced the jet nozzle fitting completely as like you say, a needle did not clear whatever was the issue. It's also worth checking that after you have tried to wash the screen, open the top tailgate and see if water drips out anywhere, this shows that water is being pumped but not getting through and that you now have a leak or a disconnection. Discovery 4 HSE
Post #1309 17th Nov 2008 10:42am
To open the tailgate and try what you said i think i will need to wait untill late May 09, as there might be a possibilty of a dry day up here in Sconnie Botland Rolling with laughter Rolling with laughter
Can't use the garage, The missus has that filled up with junk ............................ Banging Head
Post #1311 17th Nov 2008 11:20am
I know that the top tailgate always drips water when you open it (and normally it all pours just inside the lower tailgate Censored ) but you'd be able to tell if there was more water than normal.
Can you hear the pump going when you try to work it? Have you noticed any damp spots in the rear of the car (indicating a leak)
Personally I think the rear wash wipe mechanism is rubbish, why they can't put one of those nozzles on that sprays nice foamy water all over the rear screen in one go is a mystery. Something other manufactuers have done very well... Discovery 4 HSE
Post #1312 17th Nov 2008 11:27am
Pump works fine, no overspill water on the top of the tailgate, no damp spots within the boot area......... Confused
Post #1314 17th Nov 2008 6:00pm
if you can gain access to the pipes, try disconnecting the pipe from the nozzle and seeing if water comes out. Then you know it's the nozzle at fault (obviously!)
I've not done this myself so I can't tell you how to get at it...sorry!
If anyone else wants lessons in How to Suck Eggs, please let me know.... Whistle Discovery 4 HSE
Post #1315 17th Nov 2008 6:49pm
Vogue
quick question,
mine doesn't spray but literally floods water out over the rear screen - like a hosepipe without a nozzle... is mine normal or is it goosed???
Post #1321 19th Nov 2008 11:11am
It might not be 'normal' but at least you're getting plenty of water out, mine takes 2 washes to get clean these days. Discovery 4 HSE
Post #1322 19th Nov 2008 11:52am
jpr
mine stopped completely recently so took it into LR and they said they get at least 4 or 5 of these a week, they then basically cleared the pipe with an airjet and all done! ---------------------------------------------
Current - 2015 RR & Lumma CLR GT 558
Previous
RRS HSE now Gone
SC FFRR Gone
Post #1328 20th Nov 2008 9:55am
Soupdragon
England 2003 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Mine has exactly the same problem; hardly anything comes out at all. Perhaps RRs develop some sort of prostate problem, after all, they are a male car! Rules are made for the obedience of fools and the guidance of wise men.
Post #1364 22nd Nov 2008 6:47pm
Vogue
have you tried the squeeze and hold method Sheep Laughing
Post #1381 24th Nov 2008 11:51am
Soupdragon
I haven't but my wife has sometimes when I've been late home from the pub! Rules are made for the obedience of fools and the guidance of wise men.
Post #1393 24th Nov 2008 8:38pm
