Home > Technical (L322) > Air suspension compressor repair
Andy
I'm going to strip and rebuild my air compressor this afternoon. In short, how do I remove the compressor? When I say remove, I mean is it just a case of unplugging the electrics and the air pipe or should I be draining the air first and if so, how? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #130450 11th Jul 2012 12:03pm
havnt read through these but there might be something that might help,
http://www.fullfatrr.com/forum/topic6981.h...compressor
http://www.fullfatrr.com/forum/topic8136.h...sor+repair ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #130451 11th Jul 2012 12:10pm
Noddy if you have a RAC or IID tool just unplug it and the air line. You should only get a small hiss. If you don't disconnect the battery first then unplug. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #130518 11th Jul 2012 5:04pm
Meerbusch
Hallo, if you have NO message in your display like AIRSUSPENS.INACTIVE, than you must disconect your battery first, but if you HAVE message, it is not necessary to disconnect, because you must erase your faults with the RSW or GAP, first than the new fitted compressor will work. Are the bolts come to you? If you have any questions about fitting, you can ask me. I like to help all my clients!
Kind regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #130523 11th Jul 2012 5:16pm
klf400
When i fitted my lpg tank the suspension was in normal height i just unplugged the hose from the compressor
And it didnt even make a hiss or go down , and on reconnection everything worked fine Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #130578 11th Jul 2012 8:10pm
Andy
Yes, I've got the bolts. Thanks. Rebuilt it all today do I just need to get the fault cleared 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #130600 11th Jul 2012 10:26pm
Meerbusch
... give me info about the fitting-repair, was it easy? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #130649 12th Jul 2012 9:56am
