The strut costs @ �220 (much more if you go through LR), then definitely no more than 2 hours labour per side. You will need to have both sides changed so that the shock absorbers and bags have the same wear/usage.
DIY is fairly straight-forward if everything comes apart OK.
I have a passenger side second hand one with no leaks (guaranteed to forum user) available if you only want to change one. .
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember
