Home > Maintenance & Mods (L322) > 2002/05 facelift to 2006 +.....thoughts / advice please
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
hi everyone, i have got some bits and bobs from Gary (gazeelio) to do the facelift on the my RR. i believe that i will need some extra bits and bobs, like a high water pressure pump for instance; i was also planning on doing the work myself. so i have two questions.... firstly what are the other parts that i will need and secondly are there any threads on doing this job, or would i be better off paying someone to do it? my biggest issue at the moment is that will ave to take the wheels off to do the wheel arch liners but can i do them one at a time or do i need to jack the whole front end up as i will need both wheels off at the same time..... all help advice as usual appreciated. Bow down
Post #128148 28th Jun 2012 1:49pm
there's a 'how to' on the wiki. ... - .- -.
Post #128149 28th Jun 2012 1:52pm
andyleeds
cheers stan i did look but couldnt find it, should i just enter "how to facelift" or just how to? cheers
Post #128151 28th Jun 2012 1:55pm
http://www.fullfatrr.com/forum/topic9699.html?highlight=facelift
wiki , http://www.fullfatrr.com/forum/viewtopic.p...8707db8222
search "facelift" or "conversion" with quote marks.. ... - .- -.
Post #128152 28th Jun 2012 1:56pm
andyleeds
cheers stan, so it looks like that i dont need to take the wheels off at the same time after all which is handy....
Post #128157 28th Jun 2012 2:05pm
you're welcome andy and good luck with the job..
i've edited your title so that it will be easier for others to find this subject.. Wink ... - .- -.
Post #128160 28th Jun 2012 2:12pm
andyleeds
cheers stan
Post #128186 28th Jun 2012 3:03pm
andyleeds
do we think that i would be better off changing the arch liners before or after the bumper? as i cant seem to see any notes on this.... cheers guys
Post #128236 28th Jun 2012 6:53pm
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
i have done this you have to cut the lip off both front wings not hard to do but takes some balls
also you have to change the plugs to the lights
i have both front lights off a 06 supercharged if you want them
Post #128258 28th Jun 2012 8:11pm
andyleeds
i have actually got a new set of wheel arch liners, are they essentially the old ones minus the front wings off? so not really worth changing, might as well just cut the wings off? what did you use to cut them off, hack saw?..... i have got some new lights to put on, whats the difference between these and some supercharged ones? best andy
Post #128286 28th Jun 2012 10:06pm
highfellzippy
i used a air saw when you take your old lights off at the end of your wings there is a lip
Post #128287 28th Jun 2012 10:16pm
