Home > Maintenance & Mods (L322) > TD6 Transmission fluid |
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 |
Mine's got 119k on it and it shifts brilliantly. I'm still gonna drain and flush it, though!
19th Jun 2012 8:26am |
Right, the more I look at this, the more I'm convinced that you really don't have to use Texamatic. Total's ATF33 is broadly similar:
19th Jun 2012 10:59am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Good work, misteralz, when it comes down to it, it is your car, us none tribilogists will no doubt continue to follow the herd .
19th Jun 2012 12:40pm |
Thanks! I'm following the herd because I could find Texamatic for a reasonable price.
19th Jun 2012 12:53pm |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 |
Price today 20l Texaco ETL 7045E, Transmission Oil Texamatic 7045E
28th Jun 2012 12:11pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Whatever oil you use remember to fit a quality filter or you will regret it!
28th Jun 2012 1:01pm |
Of course. I'm currently weighing up whether to drain, then refill, then flush with old filter in place, or drain, replace filter, refill then flush. Decisions, decisions... 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
28th Jun 2012 1:05pm |
vallef Member Since: 03 Apr 2012 Location: Stockholm Posts: 10 |
I have used Dexron VI (6) as GM the manufacturer in Strasbourg of the 5L40E announced that Dexron 6 can be used. As I live in Sweden I cannot get the original Texamatic, so if you can get it I would use it. I just had to be pragmatic. I did one flush, pan drop and transmission filter change at 118,000 km, old oil coming out was black. then after a 3km test drive I just did a drain. Then after 200km I did another pan drop, filter change and drain. Now I have been running on Dexron 6 for 6 months and 13,000km all through the Swedish winter where cold starts are at -25C also quite a few summer non-stop 400km trips. Everything is OK, box was good before the first fluid change but shifting is slightly better, quiter and smoother afterwards. I did this as preventative maintenance. Takes about 1 hour to do a pan drop and flush as I have done 3 now. Summary if you can do it, try for the original Texamatic if you can, but Dexron 6 seems to be OK. I used a MPM Dexron 6, but if you look at the BMW forums they use the Mobil 1 Dexron 6 in the 5L40E transmission.
5th Sep 2012 7:56pm |
