Home > Technical (L322) > Help - Won't start |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
Your battery is flat.
9th Feb 2010 8:14am |
Alex 111s Member Since: 09 Feb 2010 Location: Aberdeen Posts: 14 |
Ta. will check when I get home tonight. Had a flat battery a couple of weeks ago but it let me turn the engine over then. (not even getting that far this time.)
9th Feb 2010 8:22am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
It seems the cold weather has caused a lot of battery issues for a number of members and the advice I think everyone would echo is, if your battery starts giving you problems, you can bet your last pound it won't get any bettter.
9th Feb 2010 8:47pm |
Thans to both of you for the advice.
10th Feb 2010 7:59am |
As RRUK's post your best replacing it or you'll end up paying for fault codes reset like I've just had to do.
10th Feb 2010 10:20am |
It's worth checking the voltage, with the engine running. It should be around 14V, even with accessories on. Although if I load everything up 4 heated seats heated screens, steering wheel, blowers, lights etc it drops to below 12V at idle, but picks up to just over 13 over 1000 rpm.
10th Feb 2010 10:52am |
