Td6 wouldn't start then next day it fires up as normal! | |
Car drove normally yesterday, parked it up for an hour then when I got in a tried starting it (starter motor and battery both as normal) but it would not catch or even try catching.
- I tried unlocking and locking incase it was the immobiliser, but no difference.
- I wiggled and changed the gear selector but no difference.
- I checked the fuel hose, seemed ok with fuel in it.
The recovery guy checked the fuel filter, but he seemed a bit confused about the L322 diesel pipe set up (FBH etc) but he thought it was a fuel pump/blockage issue. So got him to drop it off at the garage.
He rings me after dropping it off and said it started up perfectly whcih surprised him. I called the garage this morning and they said same thing.
Just wondering if it is a common fault, and whether it could just be some floating debris in the tank that is causing a blockage. Is it easy to clean out and fix? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
