Home > Maintenance & Mods (L322) > Squeaky Rear Suspension
mjdronfield
I've done a bit of a search, and guess that as my car sounds like an old pram (quote from another thread - made me laugh), from the rear, that the rear suspension bushes are at fault.
I take it original LR is the best route for replacement, but my query is whether they are actually knackered, or do they just squeak, but are fine ?
Has anyone managed to cure with WD40 or such like ?
Prob have to live with it for a bit and go and get all the bushes changed......
It started when I did a 3 point turn, using a bit of a grass bank. I guess the car hadn't seen such axle articulation for a long time............
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #127299 23rd Jun 2012 2:09pm
Folks have had success with WD40/silicone lubricant etc, it is getting it into the right place that is the hard part, using syringes with needles etc to force the lubricant into the bushes.
A good squirt with your preferred lubricant on one bush at a time may help to identify the one with the problem though .
Post #127307 23rd Jun 2012 2:50pm
Blinkinlights
Canada 2006 Range Rover HSE 4.4 V8 Zambezi Silver
I was talking with a four-wheeler buddy of mine who suggested replacing the bolts with ones that have zerk fittings on them. It seems that the industry has come up with a possible sollution and they are used in extreme conditions. Does anyone know the size of the bolts that are used with these bushings? 2006 HSE
Post #127441 24th Jun 2012 4:05pm
I had to look it up. A zerk bolt has a grease nipple at one end so you can grease the mating face of the bush in situ. Which is nice. .
Post #127443 24th Jun 2012 4:52pm
It's not the bolt that squeaks it's the inside of the bush that wears and salt water enters and damaged the grease which in turn screws the joint
Sadly new zerk bolts won't sort it, new bushes are the only way to go :blub:
Post #127449 24th Jun 2012 5:51pm
Blinkinlights
Second question is about the bushings and the control arms. Are they both aluminum or steel, and is there a problem with dissimilar metals? 2006 HSE
Post #127473 25th Jun 2012 1:19am
They are all steel as far as I know
Post #127476 25th Jun 2012 5:55am
mjdronfield
Sort of going back on what I said at the beginning, I was planning on changing like for like, with genuine Land Rover bushes, but if they are a bit prone for doing this, are the polybush ones the way to go ?
See what you mean about getting access with oil !! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #127497 25th Jun 2012 8:27am
As far as I know there are no poly bushes available for the FFRR as yet, plus poly bushes will not give as much comfort as original bushes. Stick with original as they will outlast the time you own the vehicle
Post #127499 25th Jun 2012 8:35am
mjdronfield
Famous Four do a complete polybush kit for front and rear;
http://www.famousfour.co.uk/new_parts/part_page.php?partID=15764
Will be sticking with original parts.
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #127500 25th Jun 2012 8:50am
@ 47p2
Got any photos of the getting them out and putting back in?
What is the best process to change the lower bush in situ? .
Post #127509 25th Jun 2012 9:20am
No pictures Joe but here is an excellent write up on the Saab forum showing the procedure and the FFRR is similar. Remember to get a new circlip for the bottom bush when changing it Thumbs Up
Post #127522 25th Jun 2012 11:27am
Thanks 47p2
Looks like the saab guy had a bit more access. A good link to the process. And thanks for the tip about the circlip. Dan get back off holiday! .
Post #127528 25th Jun 2012 12:14pm
The bushes will be as tight as getting a fiver out of Stan's wallet...well maybe not that tight. I used a 5' steel bar and a 7lb hammer to break the rust seal before attempting to pull them through
Post #127533 25th Jun 2012 1:05pm
mjdronfield
Just got back from the garage, and apparantly there is excessive play in both rear lower hub bushes........
Will now have to decide what to do.
Is it something I can ignore, and live with the odd squeak ? Probably not, and will at least be raised at the MOT in September........... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #128126 28th Jun 2012 12:39pm
