Home > Maintenance & Mods (L322) > Smokey Exhaust |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
Just to rule out the td6 engine does appear to smoke under acceloration but its mostly noticeable at night when you look in the rear view mirror
20th Jun 2012 10:52am |
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 |
It's a thick heavy blue smoke which stinks. I can start the car, no smoke, drive for a mile lots of smoke, pull over and let the idle until the smoke stops then carry on with my journey and no more smoke. But I am too scared to drive her at the moment until I know I am not making thingsorse. |
20th Jun 2012 11:35am |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
have you changed the breather yet? if not theres no point worrying until you have. most common cause of burning oil and turbos being replaced unnecessarily on all bmw engines is the breather being blocked causing excessive pressure in the engine forcing oil and pressure out were it can which is normally the turbo seals and valve stem rubbers casing alot of smoke out the exhaust. |
20th Jun 2012 11:24pm |
Hi Arron, not yet. The mechanic I know really well works for Vauxhall and is waiting for his friend who works for Land Rover to let him know what to do. I think I will order the breather tube assembly and ask him to start there. The trouble is I don't want to tell a mechanic what to do, especially a mechanic who doesn't like forums. But you guys own these cars and know what you have done to put things right, perhaps I will have a go myself.
21st Jun 2012 5:45am |
Better having the Vauxhall mechanic fix your FFRR, the Land Rover mechanic won't have a clue what he's doing |
21st Jun 2012 5:54am |
Probably right there, it's amazing that they have never had a car in that smokes or never worked on the EGR valve |
21st Jun 2012 6:39am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Your money your car! Mechanic should do whatever you tell him. Worst he should do I say "told you so". Know which option I would be doing. £40 on a breather or £1kish on turbo pistol rings? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
21st Jun 2012 7:07am |
I am not being forceful enough, he should know how impatient women are, if he doesn't come back to me today then I will have a go myself at the weekend as I can't wait any longer. |
21st Jun 2012 7:52am |
Ifu get stuck just let me know i will try too help onto no6 Range Rover
21st Jun 2012 9:38am |
Breather assembly ordered and car booked in tomorrow, yippeeeee |
22nd Jun 2012 7:50pm |
All done and Smokey Jo is no longer Smokey . The filter was absolutely solid , why aren't these changed during normal servicing . Now onto the next project.
23rd Jun 2012 4:02pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
result glad it didnt turn out to be more costly... ... - .- -.
23rd Jun 2012 6:59pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Because the parts changers can't be arsed to do it. And if it isn't mentioned in the schedule then it isn't done. Lets not start about changing TD6 gearbox oil. Adrian VW Amarok 2014 Highline auto |
24th Jun 2012 8:32am |
Oh no, how often should that be changed Adrian, . I bet that hasn't been touched |
24th Jun 2012 12:43pm |
