Home > Maintenance & Mods (L322) > TD6 Transmission fluid
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Hi,
I'm now well into the process of joining the rangie club and getting on 05 plate vogue TD6. Dealer has just put it through an MOT for me and having a few last checks done before i get the keys late next week.
Shes not to bad milage wise - 64k, which makes me think i need to perform a bit of preventative maintainance almost straight away:
I've read a few conflicting things re. the automatic transmission, some documentation says the Tranny is sealed for life, and other people say that you should change the oil at 60k to stop it cooking. Is that the case? is 60k about right? Also, thinking of taking this to an automatic gearbox specialist (Briggs Motors - Fareham UK) Any idea of what i should expect cost wise to gauge his quote against?
Secondly, whats the service interval for the cambelt on the TD6? is it 60k or 80k? not been able to find this anywhere.
Many thanks,
Dave
Post #76287 15th Aug 2011 12:15pm
Googsy
No belt on TD6 its a chain so should last life time of engine cant comment on gearbox as I have a TDV8.
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #76288 15th Aug 2011 12:28pm
Have a read of this re gearbox
http://www.fullfatrr.com/forum/topic1259.html
Post #76289 15th Aug 2011 12:30pm
DaveAngel
Thanks Guys, from reading that i think i'll get it done (the transmission, not the cam chain - bonus Smile ).
Briggs motors said in the region of £100, so i think i'll let them take the pain for that, although i'll check to make sure they are using suitable oil and swaping the filter.
Post #76293 15th Aug 2011 12:59pm
I've been quoted at a local auto box specialist £85 +vat and it would take 3hours for the work and just to bring it in warm so it drains more eaisly Smile
I'd ideally like a flush like the tdv6 guys can get but its apparently not availabe on the FFRR though i cant see why not as we have a cooler for the fluid so should be possible...
Post #76298 15th Aug 2011 1:53pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
with low prices like that i would ask what oil there putting in, its supposed to be texamatic 7045e oil which is developed for that gearbox. the oil cost 15 quid a litre and changing the filter with it normally takes around 6 litres to refill it, so taking the cost of oil added to the price of the filter plus there labour doesnt take a genius to work out they wont be using the recomeneded oil.
Post #77017 21st Aug 2011 11:55pm
Genuine Land Rover filter and sump gasket will give no change from £100, and Texamatic 7045E will cost £15 per litre plus VAT. If you remove the gearbox sump plug you will only be able to drain around 4 litres of ATF at a time. Removing the sump and replacing the filter will allow around 7 litres of fluid to be changed.
Texamatic 7045E can be bought for around £65 for a 20 litre drum if you shop around, aftermarket filter and gaskets around £55 (I don't know the quality of these items) so for a garage to take on this work for £85 doesn't sound right.....and it will not take anywhere near 3 hours.
My preferred method for changing the ATF and filters would be:
Remove sump plug and drain ATF
Refill and start engine working through the gears.
Repeat the above another twice....(well you have 20 litres of ATF at a very good price)
Finally drain the sump, remove the sump, replace the filter, replace the sump using new gasket, refill to correct level......Job done.
Some folk mention removing the cooler pipe and spinning over the engine to allow more fluid to be removed. I have discussed this with several mechanics and they all say it's not recommended, therefore I have never done that.
Post #77024 22nd Aug 2011 6:50am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Gents
Just joined the forum but had gbox issues on my TD6 in the summer, I ended up getting a 20 litre drum of Texamatic 7045e from a oil specialist in Stevenage, Herts (cant remember name of the place) for about £85 delivered. Was enough to go into the rebuild I had to get done Sad and for the yearly oil change I got to have this coming summer to keep the warranty valid.
Just bit of info seeing as a lot of people are saying up to £15 a litre
Happy shopping Thumbs Up
Post #103396 24th Jan 2012 10:25pm
There are a few places selling Texamatic 7045E at £65 for a 20 litre
Post #103398 24th Jan 2012 10:48pm
This is where I got my 20 litre drum from
http://www.fleetfactors.co.uk/lubricants-c...7045e-p387
£58.82 plus VAT .
Post #103405 24th Jan 2012 11:38pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I bought 20L of Texaco 7045E from Watsons Oil (Google them) for £66 delivered (including VAT)
Post #103470 25th Jan 2012 1:09pm
ahebron
New Zealand
Treading very carefully here.
I did a bit of research into the oil for the TD6 transmission today and came up with these.
ELF - PRESTIGE LL
AMSOIL - Synthetic Multi-Vehicle Automatic Transmission Fluid (ATF)
Full Synthetic Multi Vehicle Automatic Transmission Fluid- Nulon Australia
Now I have always thought of Nulon and Amsoil as bit like snake oil but I have reason why, maybe its the names.
All the above claim to be replacements for Texaco Texamatic ETL-7045E.
Texaco Texamatic ETL-7045E is not easily available here in NZ apart from the dealers if they stock it.
Thanks
Adrian
Post #105812 7th Feb 2012 6:48am
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
Just as an addendum to this topic, I've been doing some research of my own and spoken to an ex-colleague of mine who works for BP in their lubrication division and he recommends Castrol Transmax Dextron III Multi-Vehicle. Reading the technical data sheets of both this and Texaco 7045 reveals very few differences, with the Castrol product being arguably superior. Unfortunately, it only appears to be available in 1 litre bottles over here at £10 a pop, so 7045 is still the better option, but if you can buy it in bulk elsewhere then I wouldn't think twice about it if it was cheaper.
Post #126727 18th Jun 2012 3:00pm
But you know what everyone here will say if you don't use Texamatic ETL-7045E and your back in three months with a gearbox problem Laughing (I see you went for Texamatic ETL-7045E so good call) .
Post #126739 18th Jun 2012 5:03pm
misteralz
Yep. Laughing I'll do a proper flush when I get it, then a drain and refill every year. We'll see where we are in a few years' time...
Post #126743 18th Jun 2012 5:26pm
