Home > Technical (L322) > blocked rear window washer jet in 2003 RR
rmackinnon
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Any ideas how best to unblock?
Post #126342 15th Jun 2012 2:25pm
Type "rear washer" in the search function..... Previously..
Post #126345 15th Jun 2012 2:34pm
daveo
pull the trim of that covers the motor, you will see a black filter in the water line, will almost be certain it is that blocked, remove and pump water through, watch out as you will get a lot of black crap come out.. V8 facelift Range Rover Autobiography 22" wheels.
Post #126374 15th Jun 2012 5:29pm
stu
might be a good idea to remove the boot lid spoiler too to gain access to the nozzles properly and clean all the crud out where the water comes through under the cap into the nozzles.
just a thought Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #126526 17th Jun 2012 9:13am
