Home > Technical (L322) > Central locking gremlins???
daveym
United Arab Emirates
Ever since i bought the car the remote central locking hasn't worked from the key fob, i've always locked and unlocked the car with the key in the door (Vogue 2003 4.4V8). I've tried syncing using the ignition on off within 5secs BCU mode and then program key that way, doors lock and unlock quickly and then i immediately turn the ignition on again....it works for about 5 mins with the fob but then it seems to forget the keyfob. I've done it numerous times but all with the same results. In fact yesterday was better it lasted for about an hour - to which i thought yes finally it works Confused I've searched and searched the different forums (this is the best one Very Happy ) and i can't find an answer to my problem...has anyone had the same problem if so what was your fix?
I've sent my BCM data to Storey Wilson and he says he can't anything wrong in the data string from the RAC. Plus my stereo FM reception has just taken a dive - connected?
Standing by for someone to say have you searched.....in answer to that I have honestly searched
Post #126379 15th Jun 2012 6:08pm
could it be the batterys , in the fob or fullfat.. ... - .- -.
Post #126421 16th Jun 2012 9:46am
daveym
I've tried new battery in both the fob and FF
Post #126428 16th Jun 2012 10:08am
other than you trying the other key i cant think of anything except the bcm or connections being faulty.. ... - .- -.
Post #126430 16th Jun 2012 10:12am
I had a similar fault in a Discovery I owned.
Turned out the aerial lead wasn't connected to the ecu.
Different system in an FFRR but I would be inclined to look at the connections to the RF receiver and the aerial amplifier.
Could even be a fault on either of these components.
Located in the boot but where exactly I don't know. Very Happy
Post #126433 16th Jun 2012 10:28am
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
car could be in transport mode free use of "RSW" all comms to anyone nearby
Post #126454 16th Jun 2012 1:13pm
