Home > Maintenance & Mods (L322) > Suspension "Clunk"
Page 3 of 3 <123
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I've had a knock on the front suspension since buying my FFRR & recently replaced the front drop links, this smoothed things out on the open road but there is still a clunk when going over rough ground or speed humps.The drop links were certainly worn in particular at their top ends.
I've just completed a thorough check on the suspension & found that the front off side track road end is shot. I'll add a posting letting you know if this settles the noise down when I change that link.
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #115444 29th Mar 2012 3:04pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
A few of us have this knock, even the two main agents I've been to can't find it Sad Range Rover 4.4 V8 Vogue
Post #115445 29th Mar 2012 3:08pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If it was previous to a 2006 vehicle where they changed the transmission/engines - it could well be the front diff? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #115446 29th Mar 2012 3:11pm
Glideman
diff has been done on mine, most of them will have exploded by now anyhow Laughing Range Rover 4.4 V8 Vogue
Post #115448 29th Mar 2012 3:14pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Cars back! Replaced Drop Links on both front corners and also the lower suspension arm.
It is handling much better than before and the "clunk" is certainly milder ... but it still there. Garage said they even took the car across to AJD Landrovers and they also had a check and everything at the front end is sound. There is a slight knock from the back which they suspect might be what I am hearing ... going to get the wife drive the car tonight and I'll hang out of the window and see if I can hear where its come from - front or back - however the noise is better!
if only garage had listended to me after the first post on here and changed the drop links then Smile
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #115946 2nd Apr 2012 9:38am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Just a thought....
Wondering if the engine mounts are weakening with age, they're hydraulic/vacuum operated.
The reason I'm thinking this, is that my hand was on the gear lever, and I could feel the knock through it, so the knock feels more body than suspension. Confused
Going to get underneath and see it I can see any obvious wear (metal to metal) on the engine mounts.
Post #125592 10th Jun 2012 3:03pm
edward.barry
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
Be interested in your findings, let us know how you get on
Ed 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
2005 Subaru Legacy Outback (the wife's)
1981 2.5 Opel Commodore
Post #125684 11th Jun 2012 2:59pm
mikeyyn
supension clunk
I noticed a clunk over rough ground for the last few weeks, turned out to be my bottle jack bumping about in the spare wheel well after tyres changed! Rolling Eyes
Post #126080 13th Jun 2012 9:54pm
dantheman
Also have a knocking emanating from OSF...
All suspension components and ball joints solid with no movement.
However, since allowing to develop everything is still tight, but I'm experiencing slight wheel wobble at about 70-80MPH when slight left steer applied; as if the OSF suspension strut has failed and is not dampening as it should.
Hoping to nail this first time around - both a good friend and I seem convinced that the air strut is at fault. Due a service and MOT in the next couple of weeks anyway, so will see what emerges on test (if anything) before changing.
Will keep you all in the loop.
Dan
Post #126273 14th Jun 2012 11:38pm
JarrahJack
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I solved mine by ensuring that the compliance bushing (http://www.ebay.co.uk/itm/RANGE-ROVER-L322...766wt_1139) bolt was loosened then tightened only when the wheel was on the ground and the suspension was at normal height. Often dealers during the front diff recall loosen and tighten the bolt when the vehicle is on a hoist, this caused the bushing to twist when the vehicle is lowered to normal height. This solved both my clunk and wobble (and associated tyre wear). Depending on the state of the bushing it may need to be replaced.
Jack
Post #126413 16th Jun 2012 3:40am
supershuttle
I had this problem, went to local independent yesterday they put it on ramp and it was obvious that the nearside ball joint was goosed, they even let me duck under and have a look, it rattled around just by jiggling the steering wheel - boy I wish I had one of those ramps.
Anyhow they fitted a new little arm thingy which has the ball joint on it while I waited, lots of hammering and banging, relieved me of £97 and it seems fine now.
Drivers side was OK - for the moment at least Laughing Geoff
Post #133210 27th Jul 2012 10:08am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had this on my rear suspension - both sides and changed the top bush and the anti roll bar linkage. Turned out to be worn lower shock absorber mounting bolts ! Ordered 2 x from Dan and fitted - problem solved Wink
Post #133273 27th Jul 2012 4:27pm
Page 3 of 3 <123
