Confused!!!ACE- Dynamic Responce- Adaptive Dynamic | |
Hi Guys, I got really confused with ACE(Active Cornering Enhancement) - Dynamic Response- Adaptive Dynamic.
As far as I understand, ACE only available on Discovery2; while Dynamic Response is an option only available on RRS --- they are to control to make body flat when cornering, and how about Adaptive Dynamic?---is this the evolution of the previous 2 for the same purpose and available on FFRR post2010 models?
Then what is DSC-Dynamic Stability Control? what the difference between this and the above?
Many thanks in advance.
Found some from WIKI
RR SPORTS Dynamic Response also aids off-road performance by decoupling the anti-sway bars to allow maximum wheel articulation. The system in an evolution of the acclaimed ACE (Active Cornering Enhancement) system available on the Discovery Series II but is described as proactive rather than reactive
Electronic stability control (ESC), also referred to as electronic stability program (ESP) or dynamic stability control (DSC), is a computerized technology [1][2] that improves the safety of a vehicle's stability by detecting and reducing loss of traction (skidding).[3] When ESC detects loss of steering control, it automatically applies the brakes to help "steer" the vehicle where the driver intends to go. Braking is automatically applied to wheels individually, such as the outer front wheel to counter oversteer or the inner rear wheel to counter understeer. Some ESC systems also reduce engine power until control is regained. ESC does not improve a vehicle's cornering performance; instead, it helps to minimize the loss of control.
So the above is a bit clear now, how about "Adaptive Dynamic"?
