Home > General > Tyre Change defies MPG Logic?
A. Was on 255-60-18" General Grabbers getting 24.5 mpg (edited)
B. Now on 255-50-20" Nexen/Pirellis getting 26.9 mpg (edited)
I measured the diameter of each type: A. 77mm and B. 74.5mm. Both sets have @ the same amount of wear.
A. Circumference = 2420mm meaning in 1000 revolutions of the wheel I would travel 1.5125 miles
B. Circumference = 2340mm meaning in 1000 revolutions of the wheel I would travel 1.4625 miles
I should be getting a better mpg from the 18" General Grabbers but get a better mpg from the 20's?
Increased "friction" drops mpg by 2.5 miles per gallon ?
Explain.... Embarassed .
Post #126020 13th Jun 2012 5:26pm
tyre compounds and tyre pressures do make a difference tim, just be happy your getting a better mpg now.. Thumbs Up ... - .- -.
Post #126023 13th Jun 2012 5:32pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Less rolling resistance (some how) Like the loss of MPG when fitting Off road tyres.
Enjoy the extra Mpg Smile
Post #126024 13th Jun 2012 5:40pm
what are the tyre pressures for each??
I tend to run towing pressures as i like the way they feel and make the car more predictable for me but seem to have a similar kind of affect to the one you've noticed Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #126056 13th Jun 2012 8:12pm
allycraven
Tyre compound and tread profile / contact area makes a huge difference to the rolling friction of a tyre - if you get a chance you should watch teh Michelin "Mega Factory" on Discovery - very insightfull.. Embarassed
However, i think you're measurements are out -diameter of new 255x60 R20 should be 81.4cm =2557mm circumference = ~1.59 miles/1000 revs.
Sure you measured you're 20's correctly?
Post #126062 13th Jun 2012 8:30pm
A1GSS
Just do the "recalibrate after tyre change" thing in the Nav menu. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #126065 13th Jun 2012 8:44pm
is that available on older ffrr models?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #126081 13th Jun 2012 9:59pm
@ allycraven
I measured all four tyres and averaged and it came out at 745mm (a new one should be 763mm according to the etyres calculator)
But that is by the by. The fact is my FFRR is defying the laws of maths and physics (if you ignore friction and RollingRoadResistance) Cool Just remarkable that less resistance and smaller wheel circumference can create such a diffference in mpg
@ A1GSS (nearly typed Antonia's Dad Wink)
Not seen that one in the menus Question Shocked .
Post #126082 13th Jun 2012 10:04pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
255-50-18" = 712mm diameter
255-60-20" = 814mm diameter
Giving a difference in diameter of 14.33% according to Etyres calculator.
So the 20" wheels are giving false readings for speedometer and odometer compared to those with the 18" wheels.
Are you sure you have quoted the correct tyre sizes here as the difference makes one of them at least illegal?
Post #126095 14th Jun 2012 12:36am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
I think correct/standard size for FF is 255/50/20?
That's what is on mine and the dealer replaced two tyres prior to purchase, hopefully they are the correct size Shocked
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #126096 14th Jun 2012 5:06am
allycraven
Joe,
Think you need to check the figures stated gave in your OP... 255 x 60 R20 is definitely not 763mm diameter, as both oldcro and i have stated, that combo would be 814mm dia.
763mm dia would be 255 x 50 R20...
Also, I think ignoring resitance/rolling friction might just negate your comment about defying the laws of maths and physics.....Wink
Are your MPG figures from the OBC or calculated? If from the OBC, then 1 mile = X revolutions (regardless of tyre size) so an OBC "mile" in your grabbers isn't the same distance as a OBC "mile" in your nexens/pirellis.
On the smaller diameter wheels you've actually moved a shorter distance per OBC "mile", hence used less fuel... Between that, better efficiency tread profile and tyre compound I'm actually surprised you haven't seen a greater increase!
What distance are you're averages taken over and have they been exactly the same roads, driving style, time of year, weather etc. as all of these also play a massive part in fuel consumption figures as well.
I definitley see a fair drop in consumption in the summer compared to winter as i'm more likley to be a bit heavier on the right foot when tyres are warmer and roads are dry....although i try to tell myself it's because the engine is more efficient in cold winter air...
Post #126101 14th Jun 2012 6:21am
the 3 standard sizes for the fullfat are ,
255/60/18
255/55/19
255/50/20
possibly tim [joe90] has had variants of these.. ... - .- -.
Post #126107 14th Jun 2012 7:58am
Sorry am a plonker - got my 50's and 60's round the wrong way in the original post. Have edited this now.
Anyway fitted some 13" mini wheels last night and am getting 60mpg Rolling with laughter Rolling with laughter
Will be trying go faster stripes next Laughing .
Post #126111 14th Jun 2012 8:19am
Laughing
pics please re the mini wheels.... Laughing ... - .- -.
Post #126112 14th Jun 2012 8:20am
No problem:
Thumbs Up .
Post #126133 14th Jun 2012 11:21am
