Home > Technical (L322) > Third dead Alternator |
steviebabes Member Since: 28 May 2012 Location: Eastbourne Posts: 67 |
I am as hopeless with electrics as I am with mechanicals. But until someone learned in the craft comes along - are you able to measure the voltage in your battery, perhaps before and after a couple of hours on a charger? This might help identify a duff battery? 2003 4.4 HSE Epsom Green / Sand. Lovely! |
12th Jun 2012 10:25am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
What were the symptoms of the first alternator failure? |
12th Jun 2012 10:29am |
bjs Member Since: 27 May 2010 Location: Surrey Posts: 54 |
They have all been the same but the frequency is increasing (ie time between them failing is less)
12th Jun 2012 10:48am |
Might be worth having a word with these guys |
12th Jun 2012 10:52am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
barry,
12th Jun 2012 11:02am |
Thanks Stan, reserved the Bosch Battery as Varta not available.. 5 year guarantee so looks a good deal.. just under £100 !!!
12th Jun 2012 11:22am |
12th Jun 2012 11:24am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I'm as we speak in the middle of changing my alternator. Currently sat on the garage floor waiting for a phone call from the garage to tell me they have my new water pump. had a slight leak so taking the opertunity to change it out. i got my new alternator for £240 and the same garage told me they could overhaul/service the old one for about £80. might be worth a though before you put you VERY expensive landrover one in. I was quoted £700 from one landrover garage and £1020 to buy it outright! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
12th Jun 2012 1:16pm |
Hi Rob...
12th Jun 2012 1:41pm |
Considering the age of your car, I think (or actually I hope) it is a bad earth somewhere. Suggest to undo all earth connections, clean them thoroughly (white metal/bright copper) and reattach. Then cover in vaseline to prevent further corrosion. Biggest problem in car electrical systems (I drove Alfa Romeo for years ) is bad connections, just a bit of resistance due to corrosion and you have no voltage left.
12th Jun 2012 1:55pm |
ebajema
12th Jun 2012 2:47pm |
Keep us posted please, I for one am very interested. MY 2010 5.0 SC Galway green and sand interior!!
12th Jun 2012 2:53pm |
Agree with the above ^^^.
12th Jun 2012 3:38pm |
Thanks nicedayforit |
13th Jun 2012 8:55am |
