![]() | Home > In Car Electronics (L322) > remote key fob HELP! |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I ordered the key via Landrover after giving them my Vin ... And proving ownership etc ... Do I still need to get it coded by a Landrover dealer before I can use it? African Bush Junkie ... in London!
if you have ordered it through the dealer it will be coded when you get it..what they cant do is pre code it for the locking as it is a rolling code and will ask you to bring the car in, you could say at this point, is it to sync it to the car and are you going to charge for that, as it can be done by yourself. just wanted to know what have they quoted you for the key V8 facelift Range Rover Autobiography 22" wheels.
Was quoted 150 for the Key plus VAT and then £55 + VAT for the coding.
Update: Apparently the key still needs to be coded to the transpoder via a data connection to the vehicle ... So looks like there is no option but a trip to the Stealers ... |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
Had the same problem with mine... car had put itself in "transport" mode... fixed my issue with "rsw" allcomms... ![]() if your passing anywere near birmingham...your welcome to try a fix with mine free use of "RSW" all comms to anyone nearby |
