Home > Technical (L322) > Where is the relay for the heated steering wheel? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
the relay is on the back of the glovebox fuse board... .. ... - .- -.
5th Jun 2012 6:15pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Cheers do you know how to get the fuse box out? And when it's out which relay is the one for the steering element? 2003 Vogue 4.4 V8 Java Black |
5th Jun 2012 6:20pm |
i dont , sorry...it might be in RAVE or someone might know.. ... - .- -.
5th Jun 2012 6:22pm |
I'm guessing the fuse you took out was Fuse 29 … |
5th Jun 2012 6:35pm |
Yeah checked fuse 29 - sorry if this is a dumb question but is the relay likely to be attached to the rear of that fuse? The RAVE download won't work for me! 2003 Vogue 4.4 V8 Java Black |
5th Jun 2012 7:30pm |
Feed from the positive battery terminal (C0192) is supplied to the steering wheel relay and fuse 53 of the passenger compartment fuse box (C0632) on an R wire. Fuse 53 (C0583) is connected to the ignition switch (C0099 on Td6 vehicles, C0028 on V8 vehicles) by an R wire. When the ignition switch is turned to the 'ignition' position, current flows across the switch (C0099 on Td6 vehicles, C0028 on V8 vehicles) to the steering wheel relay coil (C0585) on a G wire. The steering wheel relay coil (C0585) is earthed on an N wire.
5th Jun 2012 7:49pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
there is also a module under the air bag, i would check here to see if you are getting the 12v up to the steering wheel, does your light come on the button V8 facelift Range Rover Autobiography 22" wheels.
5th Jun 2012 11:14pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Control box at bottom of steering wheel behind airbag...
6th Jun 2012 5:58am |
Light does come on but just for a second, can't get it to stay on. 2003 Vogue 4.4 V8 Java Black |
6th Jun 2012 7:21am |
Ahh, steering wheel is probably buggared then... Changed mind last week with the same symptoms... Luckily still under manufacturers warranty... Can you borrow a wheel to check both box and wheel...
6th Jun 2012 7:46am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Mine is doing the same, on for 2 seconds then switches off... I just took it that the element was gone in the steering wheel. I take it that this is quite a common fault? Might treat myself to a new one, but to be honest, I really can live without it. Previously..
6th Jun 2012 7:57am |
mark1959 Member Since: 28 Aug 2010 Location: North West Posts: 9 |
Hi posted this under "Heated steering wheel problems" but no replies received, so reposting here in the hope somebody has a pointer!!
22nd Aug 2013 5:28am |
Mark, sorry mate - this problem for me was fixed by replacing the entire steering wheel . Sorry I realise that doesn't help but didn't want to leave you hoping I had the solution! 2003 Vogue 4.4 V8 Java Black |
2nd Sep 2013 7:50pm |
I managed to track down a second hand ECU, the one that sits in the steering wheel about matchbox size, swapped the units over everything now works fine
3rd Sep 2013 9:04am |
