![]() | Home > Maintenance & Mods (L322) > Help! Potential alternator failure. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Drove to work this morning no problem. Got out of work and started car, but the bat light stayed on. Drove home with the hidden menu up and was showing 10.9-11V. This slowly dropped off as I got closer to home wih HDC inactive and air suspension inactive pinging up. Got home and shut down and now won't restart. Does it sound like the altinator is dead and not giving enough juice to charge the bat? What should the hidden menu show and what exactly is it showing? Any help would be great. If it is the alt how easy is it to change? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 ![]() ![]() |
alternators should push out around 14.5 volts on tick over...sounds like your battery is now flat and hasn't the power to get all the ecu's going to start the range .. ... - .- -.
It's a 4.4 so how will I know if it's a Bosch? Also how do I check the brush pack? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
The alternator on the BMW engine is water cooled and is sealed so I think the doide pack is not accessible. A new alternator is about £500.00
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1367 ![]() ![]() |
As above, the alt is slotted right into the engine, not bolted on like you would normally expect. It's a fairly significant job to get it out. I suppose in theory you could get the gibbons out and leave the case slotted into the engine but again, difficult to see hat your doing.
Ok. I've looked in rave and looks easy enough to change. Now can I test it or do I need to get a replacement and hope for the best? What does the hidden menu show? Is it batt voltage or alt voltage? As a note went out before and she started up but batt light was still on. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 ![]() ![]() ![]() |
From what you describe the rectifier diodes in the alternator have failed.
Ok that's good. Granted I do t want to spend £££ but I'm happy to do it if the fault is correct. I found replacement exchange for £250+postage. So happy with that. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Good price for a replacement. |
Just for info. I got a price from James Edwards main dealer and the wanted £750 for an exchange alternator and £1000+ for an out right sale. I've got a price of £240 for a new OEM part from Clwyd Auto electrics. They do recon one as well if anyone has a problem with theirs. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 ![]() ![]() |
May be worth a punt for £150 :
Would have tried but that's for a TD6. I needed one for a V8 which is water cooled |
Is it too late for this ?
Unfortuntly yes. I'm back up and running. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
